oil line backdate oil loss
I'm getting ready to backdate my '79 SC's exhaust, which means the two infamous oil lines will be replaced. About how much oil should I expect to lose during this process?
Drain the oil from the tank and the sump into an approved container before removing the lines. If you do it while stationary on a gravity based planet, you shouldn't lose any.
Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Use two 2.5 gal oil contailers with the sides cut open to drain ,then refill, carefully.
HB Kramer (4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete) (2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well. |
lines
If your car has a front cooler and stock thermostat removing those lines to back date should not effect much more than whats in those lines, maybe a quart or so
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Okay, I give in, and to think I'll have to go through this process every two years! I have a bucket I once used to drain oil so that i could adjust my valves. I'll use that to catch the valuable BP oil and then reuse. Knowing how much of a pain this is, I'm going to look into having a special cat set-up that bolts onto my early heat exchangers.
