Jupiter 911
bklyn's Avatar
Wow I almost blew my engine/HELP
Went for my Sunday morning drive and of course a problem, I will try to explain. Started off from the red light and upon shifting between 2nd and 3rd the engine red lined and would not come down. I shut off the engine and opened the engine deck and flicked the throttle level a fed times and it returned back to normal. Checking from the engine side the throttle dooes not appear to be binding, what else shoud I check? Thanks Lenny
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 11-14-2010, 08:50 AM
RETIRED
Joe Bob's Avatar
Throttle cable or pedal assembly?
2012 ML350 3.0 Turbo Diesel
Old 11-14-2010, 08:55 AM
gecc's Avatar
Check the cruise control cable housing at the throttle housing bracket.
Old 11-14-2010, 08:57 AM
Also check if the cruise control was "engaged" and then failed.....Porsche, in their infinite (electrical) wisdom, designed the cruise control circuit that should it fail.....it will fail "high" instead of "low" or "off". Makes for an exciting ride. And we say the Germans have no sense of humor !!!
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-14-2010, 09:31 AM
Jupiter 911
bklyn's Avatar
Ok I think I located it, exposed the pedal cluster and the accelerator pedal has two rods that pivot a black arm attached at the bottom to the cluster, removed the jesus clip and the plastic bushing is destroyed. Can someone guid me to the right bushing, I looked at our host but cant tell which one, Thanks I will try to get a picture up.
Old 11-14-2010, 09:32 AM
RETIRED
Joe Bob's Avatar
Give Glenn Sager or Darren a call at Pelican....they should be able to locate the right part.
Old 11-14-2010, 09:36 AM
Jupiter 911
bklyn's Avatar
Ok I did located the bushings under accelerator lever bushings and quickly ordered them along with some new pedal rubber. All the other cluster bushing look good at this time. Thanks for the quick responses, this one was easy-who knows what will be next???
Old 11-14-2010, 10:45 AM
Send a message via Skype™ to hangar21
Question
You might consider checking your pedal cluster? I just replaced my wood floor panels on my 87 cab, tons of junk around my pedal cluster. It took me about an hour to clean it up & lube before reinstalling the floor panels. Hope this helps! good luck.
Old 11-14-2010, 11:03 AM
I'd go with the bronze bushings rather than plastic at the pedal. There's a nice article on pedal cluster rebuilding on our hosts tech site. Bruce Stone out in California does an outstanding job rebuilding the clusters if you are not sure you can do yourself. While your in the tunnel might also check the little plastic bushings for the cable. Might also want to check your shift bushings at this time also.
Old 11-14-2010, 04:24 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Look at the clamp on the boot attached to the throttle body. If the screw is on the left side, move it to the front or right side. It binds on the screw at full throttle, but looks fine at no throttle. It happened to me on my 84.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 11-14-2010, 05:05 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Same as the Oil Pressure System... If it fail (open circuit) the guage peg at 5 and one might think every thing is OK
Who Will Live... Will See
Old 11-14-2010, 05:15 PM
Talking Bushings
By all means replace all the bushings in the pedal cluster. Use the bronze set. I'll guarantee that your original nylon 24 year old busings are shot. It's a relatively easy one day project. It took me a couple days as I had bracket sandblasted.
Also, order relacement hardware (clips, etc).
The difference was incredible!
Old 11-14-2010, 06:50 PM
