ninelevenick's Avatar
Snapped stud - opinion needed
Okay, I was a hasty, cocky son-of-a ***** and broke one exhaust stud because I didn't use heat. Well, I hoping I’m in luck. Please take a look at the photo. It seems like the stud broke off deep inside the hole. Is there enough thread left in the head for me to screw this one back into the hole and secure it with Locktite?
Old 11-15-2010, 11:58 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
well i think your in luck as that stud doesnt look broke but looks like it just came out of the head. i wouldnt put that one in but would get a new one and you should be fine.
good luck
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 11-16-2010, 12:04 AM
You think so, Ed? I looked at a close-up photo of a new stud from the PP catalog, and it looks like new studs have a bit more thread on the end that goes into the head.
Old 11-16-2010, 12:12 AM
Senior Advisor
James Brown's Avatar
Get a new one, screw it in, and say 10 hail marries! This is your lucky day. Some times rusted studs just unscrew like yours.
08 Cayenne Turbo
Old 11-16-2010, 12:13 AM
UNDER CONSTRUCTION!
Praise the car gods and move on:d
Old 11-16-2010, 12:15 AM
Smile
Well, I'll be damned if it did just unscrew out of there! I can now go to bed and rest easier now. Thank you.
Old 11-16-2010, 12:18 AM
Northern Motorhead
wildcat077's Avatar
Yup, i'll agree with the boys ... looks like it just unscrewed with the nut !!!
Don't forget the car Gods ... lol
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 11-16-2010, 01:36 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Question Heat
This one is not for you Snipernick Hopefully you got a lottery ticket on that day...
How much heat are we talking about? On the nut or stud?
Who Will Live... Will See
Old 11-16-2010, 02:18 AM
Luck was my lady last night for sure. About heat - many suggest MAPP or acetylene because they burn at a higher temp than regular propane.
Old 11-16-2010, 06:08 AM
Northern Motorhead
wildcat077's Avatar
Yes,get the MAPP gas, the yellow cannister ...
That's what i use and if you leave it long enough it will get anything red hot !
Cheers!
Phil
Cheers
Phil
Old 11-16-2010, 06:25 AM
JJ 911SC's Avatar
Mapp it will be...
Snipernick/wildcat077
J.J.
Old 11-16-2010, 07:13 AM
