-   -   need help getting busted ring out of case (http://forums.pelicanparts.com/porsche-911-technical-forum/57535-need-help-getting-busted-ring-out-case.html)
bb 01-21-2002 07:46 PM
I just got my 2.7 apart to rebuild the top end due to the fact that I found out I had no compression on #1 cyl. Upon taking the cylinder's off I found out that the ring's on #1 were all missing. And guess where they ended up in my case. Now I have rebuilt the top end of my 2.2 and feel very comfortable doing it, but I don't want to split the case at this time. Now for the question.
1) Any way to get all the pieces of the rings without splitting the case.
2) if I have to split the case, how hard is it?
thanks
my72911t/rs 01-21-2002 08:25 PM
busted rings
If you have busted rings you would be smart to tear it all the way down. Bottom end is easier then the top end. good luck.. I got ndone doing mine runs great now..Matt
rcwaldo 01-21-2002 09:17 PM
It seems odd that the rings ended up inside the case. That means they had to have passed by the two or three thou of piston to cylinder clearance. I would expect the cylinder/piston to look pretty ugly?
Just my .03 cents (inflation)
Chris
