Canyon Runner
Hi all, I am
having a hard time locating the OEM turn signal switch and was wondering , Are the switches able to be used in more than one model year application , Without cutting & splicing ? Can i change out my switch with another year model switch ? Thanks
The Pelican Catalog shows this:
![]() You do not show the year of your car, so it is hard to figure out which one(s) would be appropriate.
Canyon Runner
That's where it gets tricky. The car is a 70 T updated by the PO to a 81 SC . But the turn signal switch currently is the 74-75 model # 911-613-305-00 go figure , That's why i was wondering if certain years cross reference to other years without modification . Could the wrong model year switch account for my high beams not coming on ? My flash works just fine when you pull the stalk back . When you push the stalk forward for high beams , nothing . Thanks
You may be able to repair your existing switch. Check this thread for some tips: turn signal switch quick fix pictures
If I am not mistaken, the Flash to pass function is handled by a different part of the switch then the switch between high and low beams. That my be why your flash to pass still works. Also, while I am no expert, the difference between the 1970-1973 switch and the 1974-1975 switch MAY be shape of the external stalk. In the earlier cars, it is a U shaped channel and the later cars it is a round shaft. Electrically, they may be identical.
