PMO conversion, it's done...almost
I thought I would share with everyone my latest project. Replaced the CIS with PMOs. The quality of Richard Parr's product is just absolutely top notch and well produced. The biggest hurdle for me was the intake stud removal. I broke one stud due to lack of patience and without the use of heat. Luckily, there was about 1/2 inch left of the stud exposed and a stud puller with lots of mapp gas got me out of the woods. I can't wait to hear how these babies sound after I get the throttle linkage shortened so I can achieve full throttle. Thanks to Steve Weiner for all his help and advice.
Andy BEFORE DURING![]() AFTER ![]()
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) Last edited by ael911; 03-13-2008 at 01:54 PM.. |
Sorry to hear about the broken stud. I had grappled with my exhaust studs (and broke several), but my intake studs came out without issue.
Congrats on getting the PMOs installed, though. I absolutely love mine! You should consider having a local shop with a dyno give them a once-over when you're done with the install. I was surprised to recently find out that mine were set up way to lean (as delivered by PMO). All is well now, but my assumption could have lead to catastrophic failure. All is well now, but my mech had to bump me from 165 mains to 190s! |
".....but my mech had to bump me from 165 mains to 190s!"
The jet sizes used by countless other owners indicate a finite boundary for those using Weber/PMO carbs. 190 main jets are really rich. 150's or thereabouts would be more like it. However, I can't answer why that size works on your engine. Your mileage would be in the low teens or less with that size. Are you sure your tech didn't mean air correction jets instead of main jets? Sherwood Last edited by 911pcars; 03-13-2008 at 11:05 AM.. |
When I had my PMOs dynoed soon after installation, they were way too rich as delivered. Rick DeMan said the car was "a superfund pollution site" as originally set up.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Those sure are pretty. I just love carbs. Mainly becuase I know how to work on them. Kind of.
1971 Porsche 911 T Targa |
Rick's sense of humor is as finely tuned as his 800 hp GT1 turbo.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I did this, not too long ago, and ended-up with 150 mains. Webers though, not PMO.
Jon |
I hope my 135 mains aren't too lean, but I trust Richard's judgement and I will eventually have a reputable shop double check them for me. Thanks for the advice JP911
'75 911S Silver Anniversary #164(Formerly JTO's) Rebuilt 2.7 with full ARP, 9:1 CR. SSI, GHL, ER polybronze bushings, finned oil lines. Lowered and corner balanced. CIS retired, now PMOs! '65 912 slate gray sunroof (driving project) |
Andy, looks really great. i'm saving money to get my car done too. don't know what are the pros and cons on having a pmo, twin-pluggin, or swapping a 3.6. i think, money is the issue for me.
p.s. yes, i would love to hear it. i heard jon's 3.5 twin plug. awesome car jon. |
They look fantastic ! Well done Andy.
I have a 75'S with PMO's. I started with 160 mains but they were too rich went back to 150. Looks great you should love it.
PhD on Pending Projects
I love the looks of that setup and plan to do the same on my '83 SC.
Congratulations on your PMOs!!
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
Black and Blue
That sure does clean up the engine bay! looks incredible
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
FWIW,.....
Richard @ PMO generally gets the jetting close but IMHO, nobody should EVER assume that its optimal for each persons's engine as they differ. Variations in local fuel composition. ignition timing, compression ratio, camshafts & valve timing, displacement, exhaust systems(!!), local temperatures and altitude all play major roles in what the final jetting will be. In short, everything,... ![]() Add the wear & tear unknowns of an engine that is not new and one soon finds out how difficult it is to generalize. We dyno each and every carburetor conversion (new engine or not) to ensure that the AFR's are correct and anyone doing or contemplating such things should NOT skip this critical step. Assume nothing as its YOUR engine and if you are a DIY'er, you bear the responsibility to see that its not only safe to run but realize maximum performance. ![]() Well done, Andy. I'm going to keep your pics around here to show others who are thinking about doing the same thing.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks for all your help Steve, and I wish you were close by so I can get the AFRs checked by a pro. Anyone know of a reputable shop near me with dyno and carb tuning abilities?
Capitalist and Patriot
Steve, Andy or anyone else know if the PMO's can be set-up in order to pass Ca smog emissions parameters?
I've been drooling over this setup, but am apprehensive due to stringent emmision parameters... I've read in many threads most people just flat out saying it is impossible to use Webbers or PMO's in a Ca smoged 911...but with such tech expertise I find it difficult to dismiss the probability of tweaking the AFR & CO2 etc to fall within the parameters..some the domestic cars that pass are freakin nasty! There's gotta be hope, no? Maybe the PMO Fuel Inj setup instead? I ask this b/c I notice Andy is in Ca...but may be exepmt due to the MY of his 911... My current '81 w/50K on rebuilt CIS passes smog with amazing emmision #'s..the Tech can't believe how clean this 25yr+ 911 registers... BUT I'm really itching to do an upgrade on the engine 3.0-3.2 and would love to chuck the CIS for numerous reason... Any input is greatly appriciated...sorry don't mean to highjack the aweesome thread!
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Hi Andrew,
You have done so many things to enhance that beautiful little car. The PMOs are the cherry on top. Congratulations. I hope to be down next week so I can see and hear her run! Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Hey Troy,
The real truth is you are the one who has done so much work to this car to get it to this point. I am just trying to keep the tradition going... ![]() I hope you can make it down next week too. I am going to shorten that accelarator rod with Steve's advice to cut and braze it back together with a brass sleeve. Hopefully you and I can tune this thing over a few Sierra Nevadas... 911 Freak: I personally don't know of anyone in this state that can pass smog with carbs. Luckily, my car is the last MY to be exempt from smog. That is one of the main reasons why I took the plunge with PMOs.
If the car you want to put them on is the one listed in your sig, then you're out of luck. Post-75 cars in CA are required to have the standard emissions equipment which were on the car as it was originally manufactured -- unless you upgrade the motor to that of a newer car. In that case, you have to have the smog equipment that is standard for that newer motor.
'73 Targa |
