915 Trans Question (picture)
Pictured is an 915 output flange(4 bolt 2 pin) from a 74 915. What later years 915 transmissions will this fit as well. Not sure what year 915's that these were changed to a fine splined flange. Thanks
Grand Am/IMSA Data Guy
Pretty sure these flanges were used 72 thru 76. Fine spline and a smaller (100 mm) dia hub were used from 76 through early 85. 85 and 86 used the 108 mm turbo, fine splined flanges.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
The fine spline started with 1978 911
Bruce Last edited by Flat6pac; 11-17-2010 at 06:03 PM.. Reason: incomplete |
Close, but no cigar. 915/61s built for 1978/79 SCs also used the coarse spline, 100mm flanges.
Keep the Shiny Side UP! Pete Z. |
The finesplines started in 78 SC with 6 8mm bolts and the coarse splines with 6 8mm bolts was 76/77. The SC splines ran through mid 85 then went to 6 10mm bolts and larger hubs like the pre 76.
Bruce |
