Caveman Hammer Mechanic
ClickClickBoom's Avatar
Front suspension?
Hey,
I purchased an entire front suspension set up from a '80s era 911SC, it has an aluminum crossmember, for the price I couldn't pass it up. Ok, the bazillion dollar question will it fit my 1975 911S, which has a steel crossmember?
Eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-22-2010, 04:36 PM
Chuck Moreland's Avatar
The 911 sc front suspension is identical to the 75 in every respect.
It is possible the struts are a different brand, but that was merely a factory option.
Your 75 had an AL crossmember when it left the factory.
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-22-2010, 04:52 PM
Chuck,
Actually the struts were absent so it wasn't quite complete. I wanted to be able to assemble the front "A" arms to the crossmember using............wait for it............... a set of Polybronze bushings at my leisure. I will be using a Weltmeister through body sway bar and had to grind the sway bar mounts off and drill and weld bushings into the "A" arms. Thanks for the info!
eric
Old 11-22-2010, 05:37 PM
I know this is kind of abstract, but what is a front crossmember with "A" arms, torsion bars, sway bar, and adjusters worth? All stock from a 1975 911.
eric
Old 11-22-2010, 06:18 PM
about $300
Old 11-22-2010, 06:29 PM
Thanks Chuck!
eric
Old 11-22-2010, 07:40 PM
Evan Fullerton's Avatar
Not all '75s had aluminum cross members, mine has a steel one and is a 6/75 build.
Old 11-22-2010, 08:03 PM
Wait, I thought after 73 all the cross members were aloy.
Is there a chance a 74 non S might have steel?
Old 11-23-2010, 07:41 AM
My 74 911 came with steel.
Old 11-23-2010, 08:17 AM
Home of the Whopper
Originally Posted by ClickClickBoom View Post
Hey,
Eric
The steel crossmember has welded on steel straps that bolt to the car. The aluminum crossmember has bolt on steel straps. If you do not have these straps you will need to make or buy a pair. The straps from the steel crossmember will not work on the aluminum crossmember.
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 11-23-2010, 08:33 AM
tobluforu's Avatar
Since we are on this subject, I just realized that I have rust on this part from the driver’s side battery leaking battery acid. The rust is about once inch away from where the torsion bar connects and there is a hole about 4 inches long from this point and towards the center of the trunk. The connection is still okay, but it does not look all that great and could turn into a mess in the later years. So I “think” have a choice and that is to either replace the front pan. This piece costs about 175 from our host and I would then have someone weld it in. Does anyone know how much this cost to have fixed? Or I “think” I could repair the piece by myself-no pan welded in and instead add coilovers since it seems that Chuck has a pretty cool system for the fronts. This would allow me, I think, to get rid of the stress point from that area because I would be removing the torsion bars. Does this seem logical, or just stupid?
Old 11-23-2010, 10:23 AM
