Dual exhaust conversion - 87 3.2
for a stock 87 3.2, what do you recommend for an exhaust upgrade, and if I go to a dual exhaust, is there a rear valence conversion kit to add the second opening? I see some exhuast systems on the Pelican site, but no body panels for the valence modification.
-- Jeff
'68 912 P Coupe
'87 911 Coupe
'88 911 Cabriolet M470 M491
'16 Cayman
Old 08-02-2009, 03:45 PM
993 Hes with the flanges flipped and a M&K dual out. Very solid combo. Contact M&K.
I beleive RarlyL8 has rear valances.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 08-02-2009, 04:38 PM
Oh Haha's Avatar
1.SSI heat exchangers with an M+K muffler, 2in/2out
2. Backdate to pre-1975 factory heat exchangers with an M+K muffler, 2in/2out
3. Headers(no heat) with M+K muffler
4. Install a cat bypass pipe with an M+Kmuffler, 1in2/out
The first 3 options would give you "true" dual exhaust while #4 would give you a better sound but not be dual.
There are several muffler/header companies out there but M+K is a great product made by a fellow Pelican.
Do a search and you will find tons of info on setups and installation. Here's a good to get you started:
The ultimate exhaust sound clip thread!
Pacific Blue
Wayne
Old 08-02-2009, 04:42 PM
Ferdinand Magazine
johndglynn's Avatar
You could just buy a used Dansk or similar one-in/two-out and see how you like the noise first. They are mucho noisier with two outlets. The valance thing is easy enough to sort.
If you put a WTB in the parts forum, you should get something to get you off the ground for not a lot of money. Run a twin-out past the passenger's ears before you spend out for new stuff!
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 08-02-2009, 04:58 PM
1986911's Avatar
Here is some info on modifying your valance
http://www.fabspeed.com/videos/911%20Dual%20outlet%20Muffler%20Valance%20Cut%20in fo.wmv
I went with SSi's and M&K 2/2 on my 86 and have never looked back.
Before
After
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 08-02-2009, 05:00 PM
Northern Motorhead
wildcat077's Avatar
Fabspeed has a great looking and sounding one in two out polished stainless muffler that i installed along with a MK euro cat bypass on my 89 Coupe...
Great investment and not too loud as the Fabspeed is a dual wall muffler that significantly cuts out the resonation associated with other "cheaper" mufflers !
The oval exaust tips are just beautiful pieces of work
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-02-2009, 05:09 PM
m110's Avatar
Fabspeed also has a step by step video on how to modify the valence for a second tip on the right
1988 Carrera Coupe
Old 08-02-2009, 08:06 PM
http://www.rennspd.com/Products.asp?Task=STD&ModID=2&catID=3
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 08-02-2009, 08:12 PM
interesting statement I assume you pulled that off of their site?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 08-03-2009, 05:54 AM
Bill Verburg's Avatar
I don't know about Fabspeeds construction, but current oem Porsche practice is triple wall construction
Bill Verburg
Old 08-03-2009, 06:17 AM
When I did mine I bought a second used valance. Of course it does depend on where the muffler outlets are but most just require that the passenger side end of the valance be trimmed to match the drivers side
here's a pic w/ both the altered and original valance
JMO, but I really like the sound from the current Fabspeed dual exhaust/header setup, they are using a muffler thats a little bigger than most aftermarkets, w/ mufflers bigger internal volume usually equates to better sound control.
here's a pic of a Fabspeed I took last week at LRP
They are a bit big for most street driven 3.2s but still would work well
Bill Verburg
Old 08-03-2009, 06:26 AM
Send a message via AIM to NoLift911
RUF sells a second outlet valence that is factory matched with the first, its a mirror of the other side with the correct taper etc.
Just cutting a hole in the second oem valence will not duplicate the other side - some don't care, some do. For those that do you will want the RUF valence.
RUF's sport dual out muffler comes with the new valence...
Jeff
Old 08-03-2009, 07:14 AM
Northern Motorhead
wildcat077's Avatar
O.K. here is a picture of the Fabspeed two in one out muffler installed on my car along with a MK euro cat bypass ...
As for cutting a second hole in the valance,anybody who is somewhat handy can accomplish it in 20 minutes.
Regarding to their muffler being double walled,we are not comparing to OEM mufflers here but rather aftermarket ...
Cheers
Phil
Old 08-03-2009, 07:38 AM
Northern Motorhead
wildcat077's Avatar
Oooops,i meant one in two out
Phil
Cheers
Phil
Old 08-03-2009, 07:41 AM
I am going to suggest something else. Modify your existing muffler by adding a second outlet on the pass. side. Cut your valance yourself with a verv fine-toothed jig saw. (there is an old thread describing this). This mod will cost you about $100.00 and give you basically the same effect/benefit of spending over $1500.00 on new HE's and a muffler on your stock engine.
Ben
1986 3.2 Carrera
Old 08-03-2009, 07:48 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
I have an '87 on which I installed the Fabspeed premuffler and Dansk 1-in-2-out.
The rear valence did require cutting for the second outlet (as shown in the Fabspeed video referenced above) and I rolled the edge of the cutout a bit to make it look more "factory".
I like the sound, but yes it is much louder with 2 outlets - not so much at low rpm's but above 3k rpm it is notable.
Mine and quite a few others are shown here:
http://forums.pelicanparts.com/porsche-911-technical-forum/349342-official-modified-bumpers-thread-post3922595.html?highlight=bumper#post3922595
Old 08-03-2009, 08:50 AM
Senior Lurker
One cautionary note: It will be loud.
Love the sound of my engine, never play the radio. But I am somewhat alone on that one. neighbors complained, actually called the police. My son told me he knows when I drive the 3.2 to work; I drive within a quarter of a mile of his school and he knows it's me. So do the other boys in his class, and his teacher. She told me it was disruptive. My younger son and I play the "Lets set off the car alarms in the enclosed parking lot" game.
all I'm saying is be careful with your choice. I bought mine used and do a fair amount of track days. It's gotten louder over time. Maybe someone else could suggest how to quiet them down if you find it a bit too loud...
As DCOBRA says: Loud pipes save lives
Farnbacher Loles 2010 GT3 Cup car #87, 07 GT3, 05 GT3, 86 Targa, RSR project, 1978 Kremer, keen project Safari, Range Rover, 1969 chevelle, Isetta, Amphicar, Honda 50, Carpe Diem
Old 08-03-2009, 09:49 AM
porsher
aston@ultrasw.c's Avatar
Here's my contrib to the ultimate exhaust thread...
Flowmaster 80 series crossflow muffler 1 in 2 out #42583
(3) MagnaFlow mandrel bent elbows, 45 deg J bend # 10736
(1) MagnaFlow mandrel bent elbow, 90 deg L bend # 10706
Collector flange Summit # HED-15212
Gasket Summit # SUM-610125
(2) Hose clamps McMaster Carr # 8946K44
The sound is great: nice deep base with a raspy aftertaste. Several people have come up to me at the track and asked about it.
You can install this gear for less than $200, compare that with some of the alternatives!
Old 08-03-2009, 01:00 PM
Got a pic of this setup on the car? Weight comparo to the above and OEM?
I actually helped a buddy with this setup on his 3.2 - once all welded up and ceramic coated in a nice matte black it looks pretty sick - in fact sick enough that he thought about fabbing up a few more to sell. His sound made the 3.2 come as close to a V8 rumble that I have heard to date...I like the sound of my RUF Sport Muffler but it is heavy.
Jeff
Old 08-03-2009, 01:50 PM
porsher
I didn't weight any parts but I am sure the stock banana muffler is significantly heavier.
Yeah.....
Old 08-03-2009, 02:23 PM
