Here's a tough one...regulator, alternator?
O.k. guys, I have a long one here and need some advice/help:
Four weeks or so ago I noticed my battery/alternator light on my 1983 911 SC start to flicker at a light...I pressed the throttle and it went away...that was it. The car then sat for three weeks until I drove it two nights ago. I went out w/ my wife and after a party, we got in and started it up...the light started to flicker again and my radar detector wouldn't turn on. A few minutes later, the detector turned on! Kept driving...
Thirty minutes later the light went on again...and at a stop light I put on my turn signal...when I did this, the TACH WENT NUTS!! Bouncing over 6k and back to 1k etc. It stopped doing this when the signal turned off.. As I drove, my int lights dimmed and the radio shut-off. I went into my driveway and put on my hazzards and the engine died and would not restart!
I waited until the morning and checked my four year-old Porsche battery...very dry! I added almost six cups of water and it started right up! Now, after 30 minutes of driving, I turned it off and it would not restart.
Put it on a trickle charger for seven hours...now fully charged; started up and then started again a day later.
HERE COMES THE QUESTION: Went out an hour ago and it started right up but the light is flickering again!!! Not on steady, just flickering! WHAT CAN IT BE? Regulator? Probably not the alternator b/c the car starts fine...? YOUR THOUGHTS?
Could the battery and something else that went/is wrong (alt or reg) just be a coincidence? Interdependent? Thanks for your advice and patience reading this long post.
Old 10-17-2005, 06:53 PM
oneblueyedog's Avatar
The alternator voltage regulator is probably going out.
I think your car has the VR onthe back of the alternator. If the VR is not on the left side of the engine bay behind the plastic cover it is.
Do your headlights pulsate or get brighter when you rev up? If they just dim then the alternator isn't keeping the battery charged.
DIODES (RECTIFIERS) OR VR OR BOTH. I'd replace both since I think they are interdependent.
It's a possible DIY, but difficult getting the individual pieces if you are not a rebuilder.
Go with a new one from our host.
Check the cheap stuff too, like battery terminals and clean all the ground terminals.
78SC coupe, Silver Metallic
Old 10-17-2005, 07:24 PM
JTL JTL is offline
JTL's Avatar
This sounds exactly like what happened to me on day 2 after buying my first 911 8 years ago. The first diagnosis has a cooked battery but the problems continued. They ended up pulling the alternator and found some diodes had gone bad. I do remember the headlights flickering a little.
jt
-84 targa
Old 10-17-2005, 08:25 PM
Based on my episode with my '88, I'd sure say VR. It can exceed the proper voltage output and "cook" the battery. Ken
Old 10-17-2005, 08:35 PM
1982911sc's Avatar
Classic Voltage Regulator....which on your car I believe is imbeded in your alternator....on the top, you will have to remove the fan, and get to the alternator which lays behind the fan housing....Take out the alternator, pry out the old VR and replace with a new one...you can do this yourself...I did...it took about about two hours or so start to finish...you can buy the VR here at Pelican....this is a very common issue with these cars. Good luck.
944 TURBO!!!!
1982 911 SC Targa (loved but sold!)
2005 Cobalt SS (0-60 in 6.1!!)
2003 BMW 325i ex got in divorce
1969 912 Coupe (sold)
PCA Member
Old 10-17-2005, 10:53 PM
1982911sc's Avatar
oh by the way it cooked my battery! Good excuse to buy an OPTIMA!
944 TURBO!!!!
PCA Member
Old 10-17-2005, 10:55 PM
OK, trying to figure out if I have a VR problem too. 88 3.2 just rebuilt engine and while it was out had the alt. rebuilt. Now about 3k miles later I'm getting the alt. light coming on at stops and idle, goes off at 1500 rpms. Battery shows about 13.2 while car running.
Is this possibly the VR...?
I'm out of Town (Tulsa) so may need to see if I can drive for 3-400 miles back to Dallas with this going on or should I make sure and get it fixed here now.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-22-2010, 11:19 AM
joecrum's Avatar
I just replaced my VR due to similar issues as yours. Everything is good again. Start with the VR (it's much much cheaper than the alternator). It took me about 45 minutes to replace it.
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 11-22-2010, 01:09 PM
VR should be at the local indi P shop by 9 am tomorrow, plan to get everything apart tonight and hopefully that solves the problem.
Issue is most of my tools are at home so will probably take a lot longer than normal.
Buck
'88 Coupe, '87 Cab,
Old 11-22-2010, 01:23 PM
Fleabit peanut monkey
Bob Kontak's Avatar
There may be a torx fitting on the v reg - You can cheat with an allen wrench.
Old 11-22-2010, 02:09 PM
wwest's Avatar
"..battery..very dry..."
Overcharging the battery will boil away the electrolyte within just a few days. Surprised you didn't smell it.
Old 11-22-2010, 06:24 PM
steely's Avatar
Consider that high V spikes may not be good for the DME.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-22-2010, 08:05 PM
Can also 'cook' your wiring... start a fire, worst case. Can burn out bulbs.
Old 11-23-2010, 01:24 PM
theiceman's Avatar
This is not a "hard one "at all
take your alternaor out .. send it out to have it rebuilt and make sure they put a good regulator in it . Not a chineese one .Replace your alternator bulb in the dashboard while the alternator is out , put it all back together with a new battery and clean and tighten all grounds.. done ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-23-2010, 01:48 PM
dshepp806's Avatar
+1?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 11-23-2010, 02:40 PM
