New speakers in an 83 SC
Just completed install of new speakers in my 83 SC.
What was in the car....
Fronts were 5.25" Blaupunkts --- ~ 8 to 10 W avg rating ops
Rears were 4 X 6 Balupunkt DL 1525 1A --- sticker on magnet indicated 8 W avg rating.
I believe both to be original stock that came with the car.
Issue: poor sound quality, could not handle any bass, and could not be played loud. Sounded like a "mono" alarm clock radio.
New speakers:
Front: Infinity 5022 i (5.25")--- rated at 40 W avg and 2 Ohms
Rears: Infinity 6432 cfs (4 X6s) --- rated at ~ 40 W avg and 2 Ohms
Install:
Fronts: I did not remove any panel, door pocket, etc. Just removed original speakers. It was a bit difficult to secure the bottom two screws, but after some perseverence and patience, I got it done. Was not able to use original grills, which blends in with the black leather interior and door lining much better. New grills are silver colored plastic
Rears: Removed the originals fairly easily and dropped in the new ones. I had to use/place the included spacer (~ 1/4" high) on top of the new speaker. This spacer creates a separation between the original stock grills and the new speaker's rubber lining (perimieter). So, I was able to re-install the original grills. However, they are ~ 1/8" above the rear deck --- not very noticeable.
Sound:
Much cleaner/clearer sound. Night and day compare to old speakers. Can play music much louder. Handles more, but not enough bass. I can live with that.
However, for some reason, perhaps its due to the small cabin or cabin shape, the acoustics are just not that great in the coupe.
Next up ---- looking to replace existing head unit (after market Jensen with tape deck) with a new Blaupunkt or Alpine with.
Old 12-01-2010, 12:34 AM
In maintenance phase
daniel911T's Avatar
Cool
I'm really glad to hear it worked well for you!
You will get another pretty big jump in performance with a new head unit. The power in them has been going up steadily, and even an affordable one now can be expected to do 45W+ into 4 speakers. That will definitely give you more low end. If you're feeling really ambitious, you might want to try larger wires also, they can really help out considering how small the stock ones are. You don't need monster cable or anything like that, just some good quality mid-level stuff. Radio Shack or any car audio store should be able to hook you up. Don't spend too much, a wire that is a whole lot larger than what comes out of the back of the deck won't do much good for you.
For bass, I just saw a really trick installation that also looked pretty simple. Send a PM to theassphaltgambler . He has a custom (but quite simple) enclosure with a 10"(?) sub in the passenger side footwell, right where the piece of wood for the footrest sits. With carpet you'll never know it's there, and with bass you can't discern well where it's coming from, so the location shouldn't bother anyone. He has a massive amp running it, you could probably get away with a much smaller/simpler/lighter amp, just for sub driving.
If you just want to KISS, get the new head unit, turn the treble down a notch or two, turn the bass up a notch or two.
I look forward to updates!
Dan
Old 12-01-2010, 10:05 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I really liked the Infinities when Captain Slow posted them a few weeks back.
The Becker (e.g., CDR-210) is a nice looking radio and may be an option for you as well. I don't know if Becker has a "new" Porsche logo radio now as the CDR I think is 10 or so years old.
Old 12-01-2010, 10:36 AM
Make Bruins Great Again
Por_sha911's Avatar
Sounds like you did good. Here's a couple thoughts:
-Adding an 8" sub with its own 100W monoblock amp (I put my sub in a custom made cabinet on the floor behind the driver's seat and the amp in the front boot). It adds a ton of sound and gives you a bunch more volume with putting stress on the smaller speakers.
-Bolt the rear speakers to the underside of the rear deck. Pulling the rear deck is easy. That should give you the clearance to put the grills flush with the topside.
Joe
Old 12-01-2010, 04:42 PM
Great idea on bolting the rears to the underside of rear deck --- essentially a 'bottom mount'.
I will look into that.
Old 12-01-2010, 07:00 PM
Northern Motorhead
wildcat077's Avatar
Just a suggestion ... Pioneer makes a nice CD player on which you can turn off the display.
It's really nice for driving at night as all you have is a very discreet tiny blue light indicating it's on ...
I installed one in my 89 Coupe and along with four new JBL speakers it's a world of difference !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-01-2010, 07:06 PM
Hello,
Can you please post pictures of the rear grills on place?
Thank you
K-Jetronic student
Old 12-02-2010, 08:41 AM
Why not spray paint the speaker grilles black?
Ass-engine Nazi slot car -- PJ O'Rourke
Old 12-02-2010, 03:47 PM
Spray paint grills black --- not a bad idea. I'll look into that.
But still not a "flush mount" look as with the stock speakers. That's a trade off for better sounding tunes, I guess
Old 01-15-2011, 07:38 PM
nineball's Avatar
there is no headunit on the market that puts out 4x45rms. most are in the 14-22rms per channel output range. the numbers you are seeing, and quoting, are the max output which roughly translates into never happening (in theory it is the maximum output possible for any one instance in time, not a sustained period). the only way you will get a true 4 x 45rms is with the powerpack addon from alpine, but even then you are technically adding an amp.
Alpine KTP-445 Power Pack Upgrade your Alpine receiver to 45 watts RMS x 4 at Crutchfield.com
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-16-2011, 08:22 AM
DG624's Avatar
Bob the CDR 210 looks nice will that fit into an 86 Carrera dash?
Old 05-05-2011, 01:34 PM
Bob Kontak's Avatar
Yes - Sent you a PM regarding 210 vs 220.
Old 06-29-2011, 08:27 PM
orac69's Avatar
Ive put an Infinity Basslink 2 in the trunk of mine - its quite a small 10" sub + if you want to, you can slot in a card which turns it into an amplifier to power all the speakers also.
It doesnt kick out 000's of watts of power (like separate amps do) - but its way louder, cleaner, and gives more bass than my old ears can withstand..
Also theres the benefit of not having to mess about fabricating inside the cabin.
Infinity BassLink II 10" powered subwoofer with passive radiator at Crutchfield.com
Old 08-05-2011, 08:29 AM
Tags
speaker install
