wont idle!
So my 76 911s wont idle all of a sudden. When it is cold and i start it up for the first time it will idle. But when i take it onto the road it stalls at every stop or any time i hold the clutch in. It is a DD so I have had to come up with some very funny footwork lol
Old 11-25-2010, 04:19 PM
pete3799's Avatar
Check for a vacum leak somewhere. CIS or carbs? If CIS equiped with a pop off valve in the air box check that it is seated properly.
Pete
79 911SC RoW
Old 11-25-2010, 04:41 PM
Drisump's Avatar
Forgive my ignorance but does your car have a manual choke on carbs? Binding cable or linkage could cause this problem. If it is injected, perhaps the system to enrich a cold engine is faulty and staying on. As was said by pete, a vacuum leak could potentially cause this condition as well. Cheers
Old 11-26-2010, 07:08 AM
I had a 1976 and my question is have you changed gasoline? #2, Check the seal of the Oil Cap!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 11-26-2010, 09:29 AM
My car was doing something funny once upon a time. I found several of my spark plugs were lose, could be turned by hand. I cleaned them up, put them back in and everything ran a lot better.
Torque them down if that's it.
Vac leak would be my first guess though.
Old 11-26-2010, 12:43 PM
