Hodgey's Avatar
Porsche Crest I came across a pleasant thing today......
I am getting ready to remove the front calipers and reseal them, along with new pads all round, braided lines and new brake switches and ATE Blue.
I was prepping the caliper area so that when I do get round to doing it, the calipers will be somewhat cleaner than they are now.
Although I am not ecstatic about the cleaning of the calipers, I happened to overspray some Purple Power Citrus on the bulkhead and went to wipe it off......WOW....and so I carried on a little more.
I'll be doing some more of this on the driver side and the rear wells when I finish the passenger side.
By the way, what do YOU use to clean the calipers up?
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 11-25-2010, 01:44 PM
Recreational User
porschenut's Avatar
Nothing better than brake cleaner for cleaning calipers.
Old 11-25-2010, 06:49 PM
Hodgey's Avatar
is it safe to use brake cleaner while the calipers are still on the car?
Neil
Old 11-25-2010, 07:07 PM
Carrerax's Avatar
Yes. No problem. It is just really good at cleaning brake dust, grease etc. It also works really well on grease on clothes.
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 11-25-2010, 07:17 PM
esotoracing's Avatar
soap water and a nice hard platic bristle brush (avoid metal brushes) and finish off with brake cleaner. Ive used de-greasers too.
theres nothing like the rear end squatdown of a turbo
Old 11-25-2010, 09:25 PM
No sleep 'til... BROOKLYN
flatsixjunky's Avatar
Man, I envy you. Yours are coming out nicely. I have wasted two cans of brake cleaner and I used a wire brush on them for at least one hour on each caliper and they don't look half as clean as yours, and my car is two years younger. D%$n it.
from esotoracing
Mind explaining why?
O-
-Orlando-
'89 3.2L G-50
'77 S w '79, 3.0L
'90 T-3 Syncro
32C #16
Old 11-26-2010, 09:45 AM
rbuswell's Avatar
Porsche Crest +1
I had similar results using Brake Cleaner on mine. Good stuff but try not to breath in a whole lot of it. Not so good for cleaning your lungs.
1982 911SC
1987 924S
Old 11-26-2010, 10:19 AM
Formerly known as Syzygy
Canada Kev's Avatar
And the carpet in the living room before wifey comes home...
Kevin
Old 11-26-2010, 11:46 AM
