JED
ARCSinAK's Avatar
US 3.0 change to Euro hp spec
I have a 80sc with SSI and 107K, I live in the middle of the Pacific, Kauai, very limited access to air cooled experts. This December there is a factory trained mechanic form Canada coming on working vacation. My goal is to increase the HP on my SC, any advice would be appreciated. I want to retain CIS, what would be the 1st step. I would like to increase the low and mid range torque. Can you achieve 215hp with a change of P/C, cam ect. Thank you for sharing your knowledge, Happy Turkey Day!
Regards-
JS
Old 11-25-2010, 03:36 PM
Tired Member
DaddyGlenn's Avatar
You might consider a Euro spec piston/cylinder set, a 964 cam grind. Maybe even have your heads cleaned up for better flow.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 11-25-2010, 04:27 PM
RETIRED
Joe Bob's Avatar
Sell it and put in a 3.6. You be $$ ahead.
2012 ML350 3.0 Turbo Diesel
Old 11-25-2010, 04:42 PM
JED
ARCSinAK's Avatar
Just read Lindy's and Brads threads on there high performance 3.0 builds, 6-10K doing the work yourself. 3.6 would be sweet.
Old 11-25-2010, 05:10 PM
Band.
Backdate your exhaust and get a sport muffler, if you haven't already.
Old 11-25-2010, 06:12 PM
Less brakes, more gas!
euro911sc's Avatar
moving to full euro spec would get you there, but that requires different pistons and a complete euro fuel/air delivery system. These things are hard to find. If you want to retain your existing CIS then you are pretty limited in options. 3.2SS will run on CIS $$, but oh so worth it!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-25-2010, 07:14 PM
+1. Seems a shame to spend all the $'s for a 3.2SS and keep the CIS. PO increased the CR on my car to Euro spec (believe this is done by skimming cylinders), I added SSI's and M&K sport muffler and it runs pretty well. Others swear by recurving distributor which is not too expensive.
1983 Porsche 911SC - Arrow Blue lightweight '74 Carrera look
http://forums.pelicanparts.com/porsche-911-technical-forum/498568-overdue-intro-sc-hotrod-project.html
Old 11-25-2010, 08:24 PM
I was in the same boat, a 3.0 (SSIs and M&K) with about 200k miles and smoking! I started with a 3.6 plan but had to down scale with my economy. So I went with a 3.2 with a fresh rebuild, LSD and used the SSIs and M&K. Not a 3.6 but wow! What a change from a tired 3.0 to a fresh 3.2, also from CSI to Motronic.
Very pleased with the results! In a different economy I would have spent a few more bucks and had the ultimate with the 3.6, next time.
1981 911 SC 7 & 9 Fuchs, monoballs, 22/27 t-bars, 19/22 swaybars, M&K dual in/ dual out
Old 11-26-2010, 06:39 AM
Tired Member
DaddyGlenn's Avatar
That is an interesting idea. What can one get for a decent 3.0 these days?
Glenn
Old 11-26-2010, 06:48 AM
I asked a similar question a couple of years ago-I got some good information:
250 bhp from CIS ?
Too many cars, not enough moolah...
Old 11-26-2010, 08:32 AM
RETIRED
Joe Bob's Avatar
Depends on condition, they are getting a little long in the tooth. The 914 crowd likes them.
Finding a good 3.6 is also an issue. PLUS he has a shipping issue being in Hawaii.
3.0s can go for anywhere between 3 and 5K. Head stud condition is the biggest problem. Corrosion also kills exhaust studs making them a beeyotch to crack the nuts w/o breaking studs. Most 3.0 conversion upgrade exhaust to SSIs or in the case of a 914 going to the special HEs they use or headers.
3.6s in good condition....if you trust the seller 4500 to 7K. The most troublesome is the wiring mods, so many have been done there are more than a few to choose from. Timmins (Maryland) is one but he's a bit slow and has a day job. PMS has one, pricey and the guy is a bit much in ego....but so is Timmins. TRE does them, dunno if they sell a kit but he's generally a nice guy. TRE and PMS are west coast.
Old 11-26-2010, 08:34 AM
If you go to the last page of the "250 bhp from CIS" thread there is a post from "Bruboy" with a couple of links to threads detailing his experience this is very good stuff.
Old 11-26-2010, 10:48 AM
