wont idle!
So my 76 911s wont idle all of a sudden. When it is cold and i start it up for the first time it will idle. But when i take it onto the road it stalls at every stop or any time i hold the clutch in. It is a DD so I have had to come up with some very funny footwork lol
Check for a vacum leak somewhere. CIS or carbs? If CIS equiped with a pop off valve in the air box check that it is seated properly.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Forgive my ignorance but does your car have a manual choke on carbs? Binding cable or linkage could cause this problem. If it is injected, perhaps the system to enrich a cold engine is faulty and staying on. As was said by pete, a vacuum leak could potentially cause this condition as well. Cheers
I had a 1976 and my question is have you changed gasoline? #2, Check the seal of the Oil Cap!
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
My car was doing something funny once upon a time. I found several of my spark plugs were lose, could be turned by hand. I cleaned them up, put them back in and everything ran a lot better.
Torque them down if that's it. Vac leak would be my first guess though.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
