Innov8's Avatar
Rough boggy idle on 82SC with rebuilt engine (35k)
Recently replaced spark plug, rotor and cap (and the alternator) but I still have a hard time starting and then a rough idle. When I give it some gas, it bogs down and nearly stalls with lots of backfiring. Everything else seems normal.
I have owned the car for 5 years and 5k miles. The PO said that the valve adjust ment had recently been completed so I have do that yet.
My question is does this sound like an out of tune valve or something else. Attached is a sound file of the engine idling and getting some gas.
Thank you for your help! Patrick
04 996 AE (daily driver)
08 A3 Quattro
05 E500 Wagon
PO: 11 Raptor SCREW, 11 GTI 6sp mt, 01 Audi S4 Avanti, 95 Volvo 855 T5R, 82 911SC
Old 12-10-2010, 10:35 PM
Innov8's Avatar
Missing audio file
Can't seem to figure out how to attach and audio file... I've uploaded the file to a server and I am waiting for it to process. Sorry!
08 A3 Quattro
05 E500 Wagon
Old 12-10-2010, 10:48 PM
Band.
My guess is the Lambda Relay, under the passenger seat, in the front, on the tunnel side. When it's bad, you will have a sputtery, popping, 'can't put your foot on the gas' condition when the engine is cold. (In my experience with a bad lambda relay.)
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-10-2010, 10:54 PM
mca mca is offline
mca's Avatar
Yup. I'd look there first. You need to keep a spare with you anyhow so it won't really hurt to order a new one.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-11-2010, 11:46 AM
CIS troubleshooting.........
Patrick,
A very simple test to check if your FV is working is run the FP (engine not running). With the FP running, the FV should be vibrating (running). Use a stetoscope to hear a running FV. If it does not, inspect the FV relay under the passenger seat. Another thing to consider is your vacuum leak/s. Keep us posted.
Tony
Old 12-11-2010, 01:28 PM
