engine wires- help
Hello,
I just put the engine back into my car and I cam across the classic problem- What do these wires connect to? I am hoping that they are for the heater, ac, or cruise control because I took those out intentionally because the car is now a track car, but I'm not sure that those wires were for the heater or ac. All of these wires are coming out from the engine. The first images are of two connectors that branch off of a very thick wire in the very back of the drivers side of the car. Then there is another connector that is on a wire that goes down under the middle middle drivers side fuel injector metal air tube (sorry for my lack of knowledge of the official names). And the connector is the pink and grey wires that are connected together by a piece of black plastic and then separate again.
Flickr: flat sixerrr's Photostream
thanks
scott
'80 911 sc
'96 Range Rover
Old 11-26-2010, 03:37 PM
Scott R's Avatar
The first one is the six pin plug for the CDI and the rear heated glass relay connectgr.
The third is for the cruise control servo
The last one, "3683" is for the heater blower motor
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-26-2010, 04:47 PM
ok great, thanks a ton, that is what I was hoping for
'80 911 sc
'96 Range Rover
Old 11-26-2010, 05:03 PM
