hose-help
Hello,
I just put the engine back into my car and there is a hose that I cannot figure out where it connects. The hose is one of the small sizes that does not typically have a hose clamp. It starts at the manifold vacuum limiter. It then branches into two hoses, one of which plugs into the throttle valve housing (i think) and the other is the one that I cannot figure out what it connects to. Here are a couple pictures of the hose.
Scott
Flickr: flat sixerrr's Photostream
'80 911 sc
'96 Range Rover
Old 11-26-2010, 02:45 PM
steely's Avatar
Hi Scot,
In your other thread you mentioned the cruise control delete. This hose could be associated with that. There should be a 2nd smaller ID cruise control hose too that may now be orphaned - but double check me.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-26-2010, 03:29 PM
Ok, thanks, I agree that it may be part of the cruise control system.
'80 911 sc
'96 Range Rover
Old 11-27-2010, 12:47 PM
