SC 02 sensor wire
In a search I found many posts describing a crumbled 02 sensor connector, and describing homemade replacements for the connectors. One issue I didn't see addressed - on the SC, the wire going to this sensor is a thick green coaxial (one insulated wire inside another). Does the inner or outer wire connect to the single wire of the 02 sensor? I have attached photo (not mine) showing the wire. Thanks
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Inner. Outer is shielding only. I had this same issue and fixed it with a crimp on connector. Not a big deal. I read a bunch of posts on this and in the end I concluded that a good solid connection would do the trick. A lot of people did far more extensive fixes than I did but the car seems to run the same so I would call it a "win."
Good luck! Larry |
Thanks. That is what I'd guessed and I used a crimp too. I wanted someone to confirm it was right before I started car though.
