scottb's Avatar
Best Readily-Available Non-Brad Penn Oil?
For the sake of discussion, let's say I'm out in the 84 Targa with a bone-stock 3.2 engine with 92k on the clock, and I need oil. There's no Brad Penn to be found, but there are plenty of gas stations that sell oil and maybe an Autozone. For adding one or two quarts, which readily-available oil (e.g., Valvoline, Pennzoil, Castrol, etc.) is best? (My preference would be something that I could just leave in the engine until the next oil change.)
Thanks!
1984 Targa
Old 11-26-2010, 08:55 AM
FrinkFrog's Avatar
Send a message via AIM to FrinkFrog
I'm no expert, but have often read not to mix oil brands or viscosities. It is more prudent to carry with you a couple extra qts. of the type of oil you are running than to mix in something else. Others here may have differing opinions, but I purchase the BR by the case and always have one or two quarts with me wherever I go. On long trips, this also goes for my brand of injector cleaner.
'83SC
'76 911S - Sold.
Old 11-26-2010, 09:02 AM
AlfonsoR's Avatar
I agree with not mixing brands.
I buy the mobil 1 v-twin 20w50 at Autozone. This has 1800 ppm zinc and 1700 ppm phosphorus.
They also carry the M1 10w40 racinf 4T.
Old 11-26-2010, 09:16 AM
RETIRED
Joe Bob's Avatar
For those of us that prefer Dino oil.....?
2012 ML350 3.0 Turbo Diesel
Old 11-26-2010, 09:30 AM
Bye, Bye.
Scooter's Avatar
I used to run Harley Davidson oil. It is a great oil and is readily available just about everywhere these days. I now run BP, but that is only because it is very easy to get here in Seattle.
Old 11-26-2010, 09:33 AM
scottb's Avatar
Just to be clear -- I'm talking about an unusual, hypothetical situation. Normally I do carry some extra BP, but what if I forget, or use it up and don't replace it, or...
So, hypothetically speaking, what should I do in that situation to get me home?
1984 Targa
Old 11-26-2010, 09:48 AM
In a pinch, I'll put any oil in to get the level right. Let's say you put a quart of Chevron 10W-40 in at a gas station. You now have around 12 quarts of oil total. 92 percent BP and 8 percent Chevron. Big deal. Drive it till your next oil change.
-Andy
Old 11-26-2010, 09:50 AM
A quart or so low is not a problem with these cars...
Old 11-26-2010, 09:56 AM
1980 911 SC
Take a cab?
Life's a Beach
Old 11-26-2010, 10:53 AM
RETIRED
Joe Bob's Avatar
Oil warning light.....I was driving a friends ride and it came on at idle. It was 5 quarts low.
Pretty sure there is a LOT of fail safe there. Not like a wet sump where there's only 4-5 quarts to play with.
Old 11-26-2010, 11:06 AM
Recreational User
porschenut's Avatar
As long as you run a proper viscosity, you could use any oil you want for tens of thousands of miles and not do any harm whatsoever. I've read all the oil threads and I'm convinced people here are going way off the deep end over the ZDDP issue.
Old 11-26-2010, 11:53 AM
muck-raker
kidrock's Avatar
I'd recommend the Valvoline VR-1. You can find that stuff anywhere and everywhere.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-26-2010, 12:01 PM
John W
Interesting answer to an oil question in the recent Panorama -- basically it said that dino oils benefit from ZDDP because they need the extra lubricant. Synthetics are better lubricants because of their formula and thus don't require ZDDP. It did say that pre 84 cars are better off with dino since the synthetics may leak in the older seals. It liked Mobil 1 0-40 or 5-40 for the later cars. Just repeating what they said, not trying to start a fued.
John
89 3.2 Targa 123k miles
Old 11-26-2010, 12:08 PM
Driver
Noah930's Avatar
Valvoline VR-1, the Mobil 1 v-twin stuff, I think Royal Purple makes a v-twin type oil, or Shell Rotella (the older CJ-4 stuff). I think the Rotella only comes in big gallon jugs, though. Or if you're out with Pelicans on a holiday run, ask someone in the peloton if they've got a spare quart in the front trunk.
But if you can't find any of that, then anything (ZDDP-fortified or not) is better than nothing IMO. 50 miles home on non-ZDDP oil is better than 50 miles on no oil. No?
1990 Black 964 C2 Targa
Old 11-26-2010, 12:38 PM
nineball's Avatar
x2. i stocked up this summer when it was 50% off. still have 5 change's worth in the garage.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-26-2010, 08:13 PM
Senior Advisor
James Brown's Avatar
On the road, look for the Harley dealers.
08 Cayenne Turbo
Old 11-26-2010, 08:25 PM
FrinkFrog's Avatar
Be careful with H-D oil. Motorcycle Oil: AMSOIL Synthetic Motorcycle Oil vs. Harley Davidson Oil
'83SC
'76 911S - Sold.
Old 11-26-2010, 08:46 PM
French Import
zippy_gg's Avatar
In a bind you can add ANY oil as it is better than running low and overheating your engine. Most modern oils will mix without a problem, and that should at least get you home where you can change all your oil if you are THAT anal retentive!
Seriously, any oil will do, even the crappiest, when in a bind.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 11-26-2010, 10:07 PM
does anyone know where to get mobil 1 vtwin for cheap?
In my local store it sells for almost ten dollars a quart!!
I would love to run this or a similar 20w50 oil but they all seem to be pretty pricey, at least the ones that people recommend
'80 911 sc
'96 Range Rover
Old 11-26-2010, 10:16 PM
nineball's Avatar
valvoline vr1 is usually under $6 a quart
Old 11-27-2010, 06:58 AM
