rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Anyone have a 150 ft lb 1/2" drive torque wrench they like?
To be used primarily for lugs (not just on the P-car).
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 12-31-2010, 01:15 PM
sudo apt-get purge 930
equality72521's Avatar
I like my Snap-on but any "quality" wrench will do.
--clutch-monkey
Old 12-31-2010, 01:53 PM
arbita1's Avatar
I have a Huskey one from Home Depot which I've had for a few years and like.
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-31-2010, 01:57 PM
SAM DACOSTA's Avatar
I use a Craftsman 1/2" Torque Wrench and I'm satisfied with it.
Sears: Online department store featuring appliances, tools, fitness equipment and more
SAM DACOSTA
1990 Porsche 911 Cabriolet (964)
2000 Porsche Boxster (986)
2002 Porsche 911 C4S (996)
Old 12-31-2010, 02:13 PM
LJ851's Avatar
WOW, mine is not nearly that heavy, perhaps because its a titanium? Ha , I really like my Ti ingersol rand 1/2 inch impact. Its light for a 1/2 gun , very powerful and like most impacts you can adjust the tightening torque. Its nice to have a powerful gun for the times when you need it. You are finish torquing with a torque wrench , right ?
Old 12-31-2010, 02:24 PM
Danny_Ocean's Avatar
Also SnapOn.
Old 12-31-2010, 02:26 PM
I always finish with a Torque Wrench on my lugs (whether it's an impact driver used to tighten, or tightened by hand lug tool.) Definitely recommended, especially if you're doing any form of track driving.
SAM DACOSTA
Old 12-31-2010, 02:29 PM
I have a 50-250 ft-lb PROTO I bought at my local NAPA many years ago - It's always still in spec on those rare occasions that I get it "calibrated".
Old 12-31-2010, 02:41 PM
Hodgey's Avatar
I have a 1/2" Husky and does just fine for me.
Neil
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 12-31-2010, 03:49 PM
Northern Motorhead
wildcat077's Avatar
SnapOn here as well ... Expensive but built to last a lifetime !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 12-31-2010, 05:33 PM
CDI p/n 2503CF3...1/2", 25-250ft-lbs.
Amazon.com: CDI 2503CF3 25-250ft/Lb 1/2"dr Computorq3 Elec Torque Wr: Home Improvement
Old 12-31-2010, 06:23 PM
j911brick's Avatar
I have allot of torque wrenches (from inch pounds to 600 ft lbs). My favorites are the Snap-on digitals. Mac and Proto are also good. Even though I buy allot of craftsman tools, you couldn't give me another crapsman torque wrench. You can get some great deals on ebay, but I don't now that I would buy a digital off of ebay though.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 12-31-2010, 06:52 PM
I have 6 torque wrenches, 2 electronic ones, 4 mechanical ones. Three of 6 are craftsman, and they are the ones I use mostly around the cars. When I need to be very accurate, I reach for my electronic ones manufactured by Danaher, one of which even measures torque angle. Technology wins everytime.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-31-2010, 08:00 PM
AlfonsoR's Avatar
I wouldn't spend too much money on a torque wrench. Torque , i.e. friction, is a very poor method of measuring bolt stretch. If you read one of the books by J. Bickford (Amazon.com: Handbook of Bolts and Bolted Joints (9780824799779): John Bickford, Sayed Nassar: Books), his book says torque has an accuracy of +/- 25%. I don't know if I believe that, maybe his experiment is based on bolting you could find at home depot and not the high quality, rolled thread bolting you might use for a connecting rod, for example. However, the point is still that measuring friction (torque applied) is not very accurate.
With that said, for some applications, torque is all you can go by. I wouldn't buy one that's too cheap either. I have a Kobalt from Lowes, goes to 200 or 250 ft-lbs, can't remember. I tested it against my Dad's Snap-on, and they were equal on tightening lug nuts to 110 ft-lbs.
I have a couple of craftsman and the Kobalt "looks" like it's better made.
Also, follow the manufacturer's care instructions. Mainly, remove the tension off the wrench once you are done with it.
Old 12-31-2010, 09:32 PM
vash's Avatar
my friend loaned me a SK wrench and it is very nice. better value than a snapon, in my opinion. about half the money.
poof! gone
Old 12-31-2010, 10:02 PM
300hp 1800lbs is the goal
pksystems's Avatar
Canadian tire Mastercraft one here.... seems to work, and lifetime warranty. Think it was only $50cdn.... that's like $50.05 USD
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 12-31-2010, 10:46 PM
haycait911's Avatar
I have a snappy digital, nice. but, I NEVER use any air tool on porsche lug nuts, and always use anti-seize. hand thread, then a bar with a 19mm socket, then torque wrench.
to be honest I usually skip the torque wrench. after 20-odd years of porsches I figure I can get within a couple of pounds by feel.
Old 01-01-2011, 12:39 AM
Snap On
Old 01-01-2011, 02:56 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
+ 1 on Snap On, you can find 'em on ebay, sometimes even with recent calibration.
Mark Petry
Bainbridge Island, WA
81 SC
Old 01-01-2011, 03:29 PM
Hazet- but for wheel lugs, any quality "click" wrench is fine; beam and dial as well, though they're hard to read when torquing wheels.
Jon B.
Vista, CA
Old 01-01-2011, 03:33 PM
