Polishing Fuchs with Dremel Tool
My winter project is to get my Fuchs back to new. I have Bev Frohm's tech article for reference. Was just wondering if using a Dremel with a felt polishing pad was OK. It's pretty small in diameter and I was unsure if this will cause any problems (like leaving behind a circular pattern). Thanks.
(btw, I have a full-size rotary tool, but it's sitting next to my sailboat 250 miles north of me. that's why I'm thinking of using the dremel). |
as long as you have all winter, the dremel should work fine.... just kidding, a larger more powerful tool will make it a MUCH better experience
I used a cheap 3/8" 3000 rpm drill from Harbor Freight. I used a Dremel around the valve stem. Worked for me. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
I'm doing this right now using 4" buffing wheels on a corded Dewalt drill (2,700 rpm).
Matt. 83 911SC 85.5 944 NA - Sold |
Band.
+ you'll drive yourself crazy with a Dremel. Get a drill and something bigger.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Less brakes, more gas!
Bigger is truly better in this case
![]() -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
If you are polishing these then yes, otherwise you'll need something much bigger!
My first love - 1993 964 C2 Manual Coupe My second love - 2021 Macan GTS |
Platinum Member
Using the Dremel will be like scrubbing the garage floor with a toothbrush....
Banned
I keep my wheels super polished. It is easy if you know the trick.
What I have found is that Mothers works great to polish, but it is a pain to wipe off. My trick is to use Mothers to polish and then water to wash it off. Screw rubbing it off like it says on the directions. I figured if the Mothers washes off your hands with soap and water, why won't it wash off the rims with soap and water. I tried it and it is the only way I do it now. I thought that rubbing it off would leave some kind of protective coating, like wax. But it doesn't seem to matter. I just polish the rims and then wash the car. What used to take about 45 minutes a wheel now takes about an hour or so for all four.
I love my mothers powerball. I got the one with the long shaft...wait a minute, that came out wrong...
The longer shaft one has a rotating sleeve so you can hang onto the shaft and put pressure on it. I use it in a drill. Excellent on aluminum mags using their mag polish (I have no affiliation, just super impressed. |
