Jack pad
![]() Are there jack pads that work on these cars? On this car the side panels come down too low to fit the jack pad in the receiver. Any thoughts? Thanks |
Senior Advisor
The jack pads are under the side skirts (non OEM), look for a way to remove them
08 Cayenne Turbo |
RETIRED
Those side skirts don't like an easy take off....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Driver
You're running into one of the problems with non-factory conversions. Factory boxed rockers had extended jack pad receptacles to accomodate the wider rockers. Doesn't look like your car has that. You might be stuck jacking under the engine case and front end. Just be careful not to crush any oil lines when you start lifting under the body.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
83 911 Production Cab #10
They are not...
wanderer It's a nightmare to take them off, and even worse to put them back. Last year I bought the plugs with the thinking of cutting the hole in order to access the receiver but you would need an extension on the jack pad post. I still have not done it. Of course I got the luxury (but would not go without it) of having a scissor lift, so I gave up on cutting the hole. This might sound strange but why do you want to access the jack pad receiver? An immediate requirement or a just in case you got a flat. BTW nothing wrong with non-factory conversions...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 12-12-2010 at 05:29 PM.. |
Senior Advisor
It's for the jack, might as well remove the jack, lug nut wrench, spare tire, compressor and install a AAA card.
08 Cayenne Turbo |
RETIRED
You might be able to add a permanent pad, cut access for the sized jack you have with an extension from under the bottom. Plug the hole with one of those push and twist plugs....it will be underneath and not seen.
You read my mind... After I got the lift, I give up on cutting the holes and decide to let CAA (our version of AAA) bring me back home and I'll do the rest saving a bundle. BTW the lift would pay for itself in about 2 years, I'm half way there
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I have used the towing service twice and was happy to do it. After all these years its hard to change thinking patterns, Basic items for car, spare tire and a jack to change said tire. Course who knows if that spare tire will hold air long enough to get to a service center. Ok thanks guys.
You can jack under the torsion bar end in the front of the rear wheel well.
Senior Advisor
But not with the stock jack, in the rain, on the side of the highway, at night, in the wrong part of town, unarmed, with a date.
08 Cayenne Turbo |
