I started with the mods today sealed up the headlight bucket s to keep out dust and started routing the wire harness to hook up both lights. I have the driving lights mounted so I can set them tonight and then I can reassemble the lights and do final assembly. The hole is covered with a rubber membrane I will get a pic of that tomorrow.
http://forums.pelicanparts.com/uploa...1292963164.jpg http://forums.pelicanparts.com/uploa...1292963222.jpg |
How much do you stick through the back of the headlight bucket? I'm wondering if the mini Morimotos wouldn't require the bucket mod.
It doesn't stick through very much I don't think it is even the thickness of the metal of the bucket I put a rubber membrane back there to seal things up and give room for the projector.
Got the driving lights hooked up and checked to see the pattern looked good as set so that is a lock all that is left is to reassemble and adjust the projectors.
http://forums.pelicanparts.com/uploa...1292973837.jpg |
Final assembly today!!!! :D
Sweet
So what's up with the driving lights beam hitting the bumper, does this hurt the spread? I don't understand the reasoning behind installing the driving lights in the bukets, is this so you can get rid of the ones in the air dam? Am I the only one that thinks that having the just the projectors in the bucket looks the best? This is a cool project and it's just my opinion.
tobluforu- I do like what Gsmith660 is doing with his lights. Personally, if I were to attempt this project which I may in time I would use a round driving light to mimic the new 911 sport classic light style. I would set the driving light slightly in board of the headlight rather than in line. To each there own.
http://forums.pelicanparts.com/uploa...1293030130.jpg Keep up the good work GSmith660 very inspirational. |
One light installed and the trim ring on the other bucket needs to have the membrane dry a bit longer then the 2nd light goes on I am going to set the lights by parking our caravan side by side and set my cutoff in the same place as the van. Will post pics when I get that done.
http://forums.pelicanparts.com/uploa...1293030395.jpg http://forums.pelicanparts.com/uploa...1293030431.jpg |
The whole car with headlights on and off.
http://forums.pelicanparts.com/uploa...1293043964.jpg http://forums.pelicanparts.com/uploa...1293044001.jpg |
G-
I'm diggin it. looks mean. Gives the car a whole new look. And I like the air freshener handin on the rear view mirror. My favorite scent.http://forums.pelicanparts.com/support/smileys/clap.gifhttp://forums.pelicanparts.com/support/smileys/nuts.gifhttp://forums.pelicanparts.com/suppo...ys/smlove2.gifhttp://forums.pelicanparts.com/support/smileys/pray.gif |
Yep, I think I have a set of H-1's for sale now.
I finally got them mounted on the car and only 1 comment do you guys not like them? The light pattern is great but I don't have a place to get a pic of the pattern right now but I will soon snowing here right now.
Jealousy G, Jealousy we all want em and you got em.
Plus it's the holidays people are caught up with last minute running around. Enjoy, they look great.SmileWavy |
I think they look great on the car. Looking forward to see the pattern they produce. How do you have the driving lights wired in? Do they go on w/ high beams or are they on a separate switch?
| All times are GMT -8. The time now is 01:22 AM. |
