can you identify this fuse...
Hi,
Can you identify this below fuse? What is it used for? I found it in the car and I cannot be sure whether there is new one instead of this one or not. I want to check to be on the safe side..
Thanks so much..
Old 12-13-2010, 12:26 PM
Car year, model? Even without that information, the fuse does not look like any I've ever seen in a 911, though I'll be the first to admit I'm no expert. Where in the car did you find it? The voltage is incorrect for a 911, the configuration of the fuse is odd for a 911 as well. Someone will probably be able to pin it down. Does your car have a dealer added AC or other non-factory, high draw accessory?
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-13-2010, 12:34 PM
hmm sorry. The car is 1984 3.2 Targa. not anything fancy. Just the electric windows..
Old 12-13-2010, 12:47 PM
On second look, it doesn't appear to be a fuse but rather a diode of some sort--note the symbol on the tab. Again, I know very little about electronics but someone will be able to help, I'm sure. Where did you find it, exactly?
L.J.
Old 12-13-2010, 03:05 PM
Porsche uses diodes but they don't look like that one. They are long and thin, not square like that one.
JR
Old 12-13-2010, 03:27 PM
steely's Avatar
I would buzz it out in both directions before calling it a diode - no disrespect intended. It does not not look like the same form-factor in the data sheet for the diode. The symbol looks more like a trademark - Are the tabs marked A or K? The 25A makes me lean to it being a fuse, although most auto fuses are spec'ed to 24V in p-cars (not 42V). on edit - err = I mean not 32V
Where in the window circuit was it found?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-13-2010, 04:40 PM
winter
Winter's Avatar
aftermarket alarm? shooting in the dark here. . . .
Tom
'76 Targa
Old 12-13-2010, 04:42 PM
AutoBahned
RWebb's Avatar
if so, then why 32 volt?
Old 12-13-2010, 04:49 PM
winter
Winter's Avatar
Googling the info on the part turned up some links related to car audio amps. . . .nothing exactly illuminating, though. Any numbers on the back?
Tom
'76 Targa
Old 12-13-2010, 04:56 PM
French Import
zippy_gg's Avatar
Question
Is there a part # or any writing at all on the flip side?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-13-2010, 05:12 PM
steely's Avatar
Typo on my part, I meant to copy the 32V value.
Dan
Venetian Blue
Old 12-13-2010, 06:15 PM
steely's Avatar
From the logo, it looks like the company is Pudenz, now owned by Littlefuse (if anyone is interested)
Dan
Venetian Blue
Old 12-13-2010, 09:06 PM
there is nothing on the back or the sides. There is an aftermarket alarm on the car but there is nothing regarding the audio system. I am taking your answers maybe it is here because of some sort of mixup... What do you think?
Old 12-13-2010, 10:26 PM
crustychief's Avatar
Was it just "in the car" or installed in a circuit in the car?
I just wanted to clarify this was installed in the car and not dropped by someone installing strobes on his/her homebuilt aircraft.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 12-13-2010, 10:50 PM
tharbert's Avatar
Another question? The white tab...does it pull out? I'm wondering if this is a slim non-spaded version of something like this:
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 12-14-2010, 07:49 AM
RETIRED
Joe Bob's Avatar
Looks like someone tossed a fuse in your cockpit to screw with you....old high school auto shop trick. Extra parts gets you a D- when presenting your rebuilt carb to the teacher....
2012 ML350 3.0 Turbo Diesel
Old 12-14-2010, 10:56 AM
