The tail light housings have the std round plug through to the engine bay and a seperate earth wire that looks like it should connect somewhere in behind the housing directly to the bodywork. The car is being reassembled after a bare steel repaint etc and I would like to keep things original. Before I did the restoration I had a simple earth wire attached to the chassis with a rivet and star washers etc. It was a little rough but it worked OK. Can anyone tell me where the earth points should be? A photo would be really helpful. The RHS housing also has another pair of wires that go to the oil tank level (tank up under the guard on the 72) Alternately I could use a spare pin in the round plugs to take the taillight earths back to the main earth stud by the CDI/relay panel.
The ground wire connects between the light housing and the chassis under housing mounting screw.
Ed 1973.5 T |
It's been a while, but if I remember correctly the earth (ground) wire should have an 8mm eyelet, which connects under the head of a bumper bracket bolt, or possibly between the bracket and chassis (where the bolt passes through).
Keep the Shiny Side UP! Pete Z. |
Mine went to a bumper bracket bolt.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Ditto, bumper bracket bolt.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
OK thankyou, the bumper mount bolt it is then by concensus.
