j911brick's Avatar
930 Clutch
I'm working on a '82 930 and the issue at the moment is the clutch release bearing. As this motor came to me in a basket there have been several missing parts. Right now what I have is a clutch release bearing (only) and there doesn't seem to be a retaining clip, spring washer, or shims of any sort. The parts diagrams doesn't show these parts and the picture (of the bearing) from the Pelican site doesn't either. Were these parts omitted for the 930 and if not, how can I order them without the part numbers...or does some have the right part numbers? Am I missing something here???
TIA
james
Home Page
Old 12-29-2010, 09:09 AM
Banned
This old thread of mine should help answer your questions:
Release Bearing Question
Old 12-29-2010, 09:36 AM
j911brick's Avatar
Thanks Ronnie, I appreciate it.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 12-29-2010, 10:25 AM
there's none of that on a 930 bearing.
206 637 4071
Old 12-29-2010, 12:11 PM
j911brick's Avatar
what keeps the bearing from falling inside the clutch prior to installation of the trans?
james
Old 12-29-2010, 12:35 PM
you hold the bearing with your fingers while the perimeter bolts are tightened up. the hole gets smaller and the bearing is captured.
206 637 4071
Old 12-29-2010, 12:55 PM
j911brick's Avatar
Does the cdic keep it from falling back inside?
james
Old 12-29-2010, 02:01 PM
it's captured as i mentioned above. it ain't goin nowhere once the 9 bolts are tightened.
206 637 4071
Old 12-29-2010, 02:42 PM
j911brick's Avatar
ok, I get it now.... thanx.
james
Old 12-29-2010, 05:05 PM
