battery disconnect
My 87 Carrera uses the electrical battery power to open and lock the car"s doors...
I installed a battery disconnect gadget to secure the car by removing the little knob.
BUT if I remove that knob, I can not lock the car...
Am I missing something? is there a way to lock MANUALLY the car?
Old 09-02-2018, 10:27 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Key
Use the key?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-02-2018, 11:13 AM
cycling has-been
bkreigsr's Avatar
Yes.
With the door open, turn the knob to pull the plunger down, close door while holding the exterior handle trigger in.
Bill K
Old 09-02-2018, 11:21 AM
What if you lock the car before you disconnect the battery?
Old 09-02-2018, 11:38 AM
cycling has-been
bkreigsr's Avatar
Your key will always unlock the car from the exterior, regardless of the power supply.
Old 09-02-2018, 11:42 AM
battery disconnect
bkreigsr, do you mean that by lowering the plunger and holding the exterior door handle and closing the door it will open with the key when there is no battery power?
Old 09-02-2018, 12:07 PM
cycling has-been
bkreigsr's Avatar
Or, do it the hard way.
Battery disconnected, exit vehicle, insert key, turn key 1/4 turn clockwise to lock car.
Entry is the reverse.
Your key will work in the tumbler regardless of power supply.
Old 09-02-2018, 02:25 PM
sp_cs's Avatar
Correct - central locking won’t work but each door can be opened independently
Shirish
1987 Carrera, Granite Green
Old 09-02-2018, 02:28 PM
