-   -   Setting Timing now speedo not working (http://forums.pelicanparts.com/porsche-911-technical-forum/581075-setting-timing-now-speedo-not-working.html)
jedwards1123 12-18-2010 08:38 PM
Hi all,
I have a 83 SC 3.0 and after working on it this morning and now the Speedo doesn't work, i washed it, checked the timing, adjusting the gear shift coupler, but now the Speedo is registering nothing. I have clearly knocked or interrupted something.
Any suggestions?
Jeff
James Brown 12-18-2010 08:56 PM
Adjusted the gear shift coupler!!!! go back and re plug in the wire that's lying at the bottom of the coupler access. That's the spedo pick-up wire.
jedwards1123 12-19-2010 01:38 AM
Spot on James
Exactly right. I knew I must have bumped something somewhere and you were spot on James. I had knocked the connector in the tunnel.
Many thanks.
