Setting Timing now speedo not working
Hi all,
I have a 83 SC 3.0 and after working on it this morning and now the Speedo doesn't work, i washed it, checked the timing, adjusting the gear shift coupler, but now the Speedo is registering nothing. I have clearly knocked or interrupted something. Any suggestions? Jeff
Jeff in sunny Western Australia 1971 Porsche 911T (under restoration) 1967 Mercedes 250SL Pagoda 2007 Mercedes SL350 2014 Audi A1 Sports |
Senior Advisor
Adjusted the gear shift coupler!!!! go back and re plug in the wire that's lying at the bottom of the coupler access. That's the spedo pick-up wire.
08 Cayenne Turbo |
Spot on James
Exactly right. I knew I must have bumped something somewhere and you were spot on James. I had knocked the connector in the tunnel.
Many thanks.
