-   -   Replacing busings in Shift Coupler (http://forums.pelicanparts.com/porsche-911-technical-forum/581165-replacing-busings-shift-coupler.html)
RichardGozinya 12-19-2010 01:49 PM
Hello all,
I am attempting to replace the bushings in my shift coupler, how do I remove the center pin? I think I can punch it out, but I don't want to risk damaging the coupler or the pin. I can't see any snap rings, thanks for the replies. Here is a picture of my shift coupler.
http://forums.pelicanparts.com/uploa...1292795333.jpg
aadrew10 12-19-2010 01:55 PM
Use a press. No pins are holding it in.
Flat Six 12-19-2010 05:53 PM
Or improvise one with your bench vise, using a small deep well socket that's a smaller diameter than the pin.
Works like a charm.
RichardGozinya 12-19-2010 10:05 PM
That's the ticket, thanks for the tip about the deep well socket.
sobamaflyer 12-20-2010 06:09 AM
There's nothing wrong w/ that coupler bushing ;)
http://forums.pelicanparts.com/porsche-911-technical-forum/569092-915-worst-shifting-transmission-ever.html
It will come out eventually, the socket, heat, PB Blaster....just keep at it.
kfosburg 12-20-2010 10:20 AM
I used this and it worked like a charm - using a small socket as suggested:
1 Ton Arbor Press
get the 20% off coupon from most auto magazines and it's pretty cheap.
Karl
zippy_gg 12-20-2010 10:59 AM
Works like a charm.
+1. I used that method and it worked great for me.
jwakil 12-20-2010 11:51 AM
Read the posting I put up a few hours before yours...jwakil
fastfredracing 12-20-2010 12:02 PM
I posted about a new trick I found a couple of months ago. I have done a bunch of these on a press, but for ****s and giggles, I recently tried pushing out the pin with an air hammer, and a blunt punch. It works like a charm, and is way easier, and faster than using a press. Just put the steel part of the coupler in a vise, and tighten it pretty good, then drive the pin out with the air hammer using a blunt nosed punch. Comes out like butter, and goes back in just as easy. I probably have done 4-5 of these since I first tried it, and it works sweet.
oldE 12-20-2010 12:06 PM
You probably have the pin out buy now, but the fastest method is to catch the square section in your vice and use a small drift to tap the pin out. (Fastfred is using a little more technology, but the same method.)
Assembly is the reverse.
Takes a few seconds each way.
Les
