Replacing busings in Shift Coupler
Hello all,
I am attempting to replace the bushings in my shift coupler, how do I remove the center pin? I think I can punch it out, but I don't want to risk damaging the coupler or the pin. I can't see any snap rings, thanks for the replies. Here is a picture of my shift coupler.
82 911 SC
3.0, 915
Old 12-19-2010, 01:49 PM
aadrew10's Avatar
Use a press. No pins are holding it in.
- Andrew
81SC
Old 12-19-2010, 01:55 PM
Flat Six
Flat Six's Avatar
Or improvise one with your bench vise, using a small deep well socket that's a smaller diameter than the pin.
Works like a charm.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 12-19-2010, 05:53 PM
That's the ticket, thanks for the tip about the deep well socket.
82 911 SC
3.0, 915
Old 12-19-2010, 10:05 PM
Obsessed
sobamaflyer's Avatar
There's nothing wrong w/ that coupler bushing
The 915 is the worst shifting transmission ever
It will come out eventually, the socket, heat, PB Blaster....just keep at it.
'73 Mercedes 450 SL
'75 911 Targa (long gone, sniff..)
http://1975porschetargarebuild.blogspot.com My Targa Rebuild Blog
"Life moves pretty fast, if you don't stop and take a look around once in a while you could miss it!"
Old 12-20-2010, 06:09 AM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
I used this and it worked like a charm - using a small socket as suggested:
1 Ton Arbor Press
get the 20% off coupon from most auto magazines and it's pretty cheap.
Karl
Old 12-20-2010, 10:20 AM
French Import
zippy_gg's Avatar
Works like a charm.
+1. I used that method and it worked great for me.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-20-2010, 10:59 AM
jwakil's Avatar
Read the posting I put up a few hours before yours...jwakil
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 12-20-2010, 11:51 AM
fastfredracing's Avatar
I posted about a new trick I found a couple of months ago. I have done a bunch of these on a press, but for ****s and giggles, I recently tried pushing out the pin with an air hammer, and a blunt punch. It works like a charm, and is way easier, and faster than using a press. Just put the steel part of the coupler in a vise, and tighten it pretty good, then drive the pin out with the air hammer using a blunt nosed punch. Comes out like butter, and goes back in just as easy. I probably have done 4-5 of these since I first tried it, and it works sweet.
No left turn un stoned
Old 12-20-2010, 12:02 PM
Kantry Member
oldE's Avatar
You probably have the pin out buy now, but the fastest method is to catch the square section in your vice and use a small drift to tap the pin out. (Fastfred is using a little more technology, but the same method.)
Assembly is the reverse.
Takes a few seconds each way.
Les
Best
Les
Last edited by oldE; 12-20-2010 at 12:08 PM.. Reason: Noting information in another post
Old 12-20-2010, 12:06 PM
