bauerjy
Guest
Posts: n/a
Question Show us your...Engine Bay Fuses
'88 3.2 Carrera. My Fresh Air Blower doesn't. With power directly to the blower unit it does. Took it out and apart - the bi-metal switch (resistor for multiple speeds) is fine. Tracing back to the fuse box in the engine bay. Based on the pic in Mr. Bentley's manual - seem to be missing a wire going to Fuse # 1 (Red one on the bottom of the stack), which is for the "Fan Passenger Compartment" according to the Relay and Fuse cover/Dr. Porsche and Mr. Bentley. Did a search on this forum and found a few others that indeed do not look like mine.
Old 04-14-2012, 10:34 AM
steely's Avatar
I think the 2 wires on the left are always hot, and the fuse w/o the wire has its power jumpered to it from in inside the holder. if you have a meter, you can verify. I only have 2 wires there as well on my 87. Bentley just shows 2 wires too. There is also a blower control unit, but I don't know it's location - this could be part of the problem.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-14-2012, 04:18 PM
fred cook's Avatar
Engine bay fuse panel
ATO fuses on custom aluminum base plate! Four fuses instead of three. The fourth fuse protects the power circuit to the MSD.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 04-14-2012, 04:39 PM
bauerjy
Guest
Posts: n/a
Thanks for the info
Thanks much for the info, diagram, and thoughts. Get my multimeter back from a neighbor today, so I can do some more diagnostic investigation. Will post findings.
Old 04-15-2012, 07:49 AM
Fresh Air Blower? Isn't that fused from the front fuse panel...it is fuse 13 on the SC.
The rear panel fuses are for the heater fans if I recall.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 04-15-2012, 07:58 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fresh air blower.
I don't have the CKT for yor model/year, however, Mystery train is correct.
Check for a corroded fuse on the fuse panel.
Here's a better pic:
pm me as needed.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-15-2012, 09:22 AM
theclaw's Avatar
I like that Fred. I've been looking to do a little upgrade back there myself. Quick search found this,
4 Circuit ATO/ATC Fuse Block
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 04-15-2012, 10:21 AM
fred cook's Avatar
Fuse block....
Better check it to see what the individual and total load (amps) capacity is. Often times these type panels will only be rated for 15 amps per fuse and 50-60 amps total. My panel is good for 20 amps per fuse and 80 amps total!
Fred C.
FEC3
Old 04-15-2012, 11:22 AM
theclaw's Avatar
Good call. Thanks.
'67 MB 250SL
Old 04-15-2012, 06:16 PM
Dave & Tonya
darcher's Avatar
Fred Cook! Please help! Are you the guy who makes ATO fuse block replacements? I would like to replace all the german fuse blocks w/ blade fuses.
Old 04-15-2012, 07:17 PM
fred cook's Avatar
Fuse Panels
Yep, that's me! I can build a main fuse panel for any 911 from 1974 thru 1989 and for 1978-79 930s. Also have a 4 fuse panel to go in the engine compartment. Right now I am at a standstill as my supplier of the fuse holders is waiting for a shipment which is supposed to be here near the end of May. Would be pleased as punch to fix one up for you then.
FEC3
Old 04-15-2012, 08:17 PM
bavaria911's Avatar
Fred,
What about a 1970T - is there an issue converting the older ones? I ask because you mention from 1974 and up.
Vr,
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 04-16-2012, 03:17 AM
