What fuel pump in a 3.6 conversion?
I have a 95 993 motor in a 78 SC, its not running great, I'm still running the CIS fuel pump and its 30 years old.
What pump would you Pelicans reccommend? Thanks.
Running a 95 993 motor in an SC.... |
Grand Am/IMSA Data Guy
I use the 84 and later fuel pump. You need at least 50 psi, not sure of the output of the CIS pump. I'd add a fuel pressure gauge to check before you spend a lot for a later fuel pump. Describe "not running great", might be something simple.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
RETIRED
I've been using my CIS pump for years....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Schleprock
We used the original Carrera pump in a '88 Carrera and that worked fine too.
Kevin L '86 Carrera "Larry" |
i have a couple of Bosch FP PDFs
one is a cross ref other is FP #'s etc for all cars including the 12 cyl one title part of a chart is listed as Cap which just might be capacity if wanted send me a pelican e-mail
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
