twin plugged targa's Avatar
How long do you coo; dpwn your valves?
Just took the 911T for a spin around the block in temps of 6 deg. Celcius (she loved it!).
After some spirited driving I cooled her down for the last mile or so at low revs and then for a minute or so parking in the driveway/garage.
Is this enough?
I would think sitting at idle stopped is also bad after a hard run as the car would continue to heat up?
cool down period would vary depending on how hot she gets and ambient temps.
Do you all have a 'rule of thumb?'
thanks
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 12-19-2010, 04:12 AM
initial's Avatar
I know cooling down after a morning run is beneficial, but for a 911?!?!?
Do the pros and cons of stretching also apply here?!
95 Carrera 4 Black/Black Coupe, Row M030, Bilstein HD
Past - 89 911 3.2 silver cab
Old 12-19-2010, 05:11 AM
DanielDudley's Avatar
I don't worry so much about it as I do with a turbo. I wouldn't idle it though. Idling a turbo keeps the oil flowing at idle with relatively little exhaust flow to heat the manifold. I don't see the purpose in a car that requires movement to get proper airflow.
Interesting question. I would be curious to see what others say.
Old 12-19-2010, 06:10 AM
Band.
I wait a minute or so before stopping the car when I park, but more to get more oil out into the tank, as opposed to in the engine. Less startup smoke, IMO. I could be imagining things though.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-19-2010, 06:45 AM
I can't imagine why it would matter, I just turn the key off.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-19-2010, 06:57 AM
In my motorcycle riding days, if the baffles had been removed from the exhaust, we'd plug the end of the exhaust pipe after riding to prevent damage to the valves. I've seen race cars, with short, straight exhausts also having this done. On a street 911 though, I've never even thought about it. Plenty of heat retention built into the engine/exhaust already. I'm certainly no expert but I've never heard of valve damage from failure to use a cool down procedure after a drive--even a spirited one--in a street car. Just turn off the engine.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-19-2010, 08:23 AM
Formerly known as Syzygy
Canada Kev's Avatar
I wouldn't bother idling afterward, though I usually run the car pretty gently the last few blocks before home.
Kevin
Old 12-19-2010, 12:56 PM
dshepp806's Avatar
"cooling down" would be WITH movement (air) and conservative driving for a bit after sprited stuff or stop and go traffic,...sometimes, I'll even put some extra cooling miles on should the temps be upward due to traffic hangs and stuuf,...before parking. I usually do this during the summer heat season......I have removed the rear wiper and now use this console switch to manually engage the aux (front) cooler fan when "I" want to.
I always let her idle for about 15-25 seconds seconds before turning her off.
HABITS (and protocol, I'd guess)!!!!!!!!
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-19-2010, 01:04 PM
aadrew10's Avatar
Okay guys,
I will finally tell you my secret that will keep my engine running forever. I always live by hills. This way, after a drive, I drive to the top. Then, I idle for 25 seconds. Then, I begin to drive down the hill. After I reach 10 MPH, I turn the engine off and coast down the hill and into my driveway.
Be careful not to turn the key all the way off because you won't be able to steer! I had an incident with my neighbor's trash can because of this!
I know this works because I have not had any engine trouble for the past 1845 miles that I have driven after having the engine apart.
Cheers!
- Andrew
81SC
Old 12-19-2010, 02:20 PM
dshepp806's Avatar
If it's a beasty summer down South, I'll sometimes open the engine hatch for a while.
(hehe)
Doyle
Middle Georgia
Old 12-19-2010, 02:47 PM
Non Compos Mentis
I do the opposite. A quick blip of the throttle for a few seconds before shut-down to give the cylinders a blast of cooling air.
Used to have a Turbo, and that's different. I have a long hill down towards my house. I'd coast down the hill, and use very small throttle inputs to get the rest of the way to the garage so the turbo is spooled down before shut-down.
Old 12-19-2010, 04:08 PM
safe's Avatar
In such low temperatures the engine will have no problem with heat. Just turn it off.
After track duty I drive a cool down lap, mostly for the brakes, otherwise I just turn the car off.
Magnus
Old 12-20-2010, 02:34 AM
dshepp806's Avatar
I stay away from loading the cylinders with gas from a blip.
No doubt, in the winter time, the outside air is your "cooling" friend.
Best,
Doyle
Middle Georgia
Old 12-20-2010, 01:20 PM
skinnerd's Avatar
As long as you don't have a turbo that you've been running really hard prior to shutdown.....it's a waste of time and fuel to idle your car thinking you're cooling it down before shutoff.
I'm mean really....think about it.
Air cooled, water cooled, it doesn't matter.
If this was really necessary you'd see all the major automakers recommending this practice.....including Porsche.
None do.
Simple as that.
This is the last thing you need to worry about.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 12-20-2010, 01:38 PM
KNS KNS is offline
Air cooled aircraft engines have a cool down period to bring down cylinder head temps before shutdown. I don't think it so crazy to do the same for a Porsche on a hot day...
Kurt
Old 12-20-2010, 02:50 PM
dshepp806's Avatar
Bingo!
Doyle
Middle Georgia
Old 12-20-2010, 03:05 PM
Burn the fire.
Brando's Avatar
Originally Posted by aadrew10 View Post
... Be careful not to turn the key all the way off because you won't be able to steer! I had an incident with my neighbor's trash can because of this! ...
Wow! You gotta share this one...
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-20-2010, 03:17 PM
if it's hot I'll open hood and throw a 2' x 2' fan angled on a 2x4 under engine before shutdown and keep it running for awhile after
i figure top cylinder area is most likely to coke oil and unburnt gas on cyl and piston
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-20-2010, 03:45 PM
aadrew10's Avatar
It's pretty simple really. Doing my cool down coast, I had the key off, and tried to turn, and couldn't. The girls next door had a bunch of their cheer friends over from Poly out on their front porch. CRASH! goes the trashcan as I slam on the brakes. Of course, by this time I have lost all my momentum avoiding the accident, and now like a double doofus, I'm sitting a few feet from my driveway with a car that's turned off all while being stared at by a dozen of the cutest shocked/confused faces I've ever seen. I have to start it up in order to drive the last 20 feet to its spot. I don't say a word as I retreat to the safety of my garage. I'm friends with a few of the witnesses and the next day they told me how half the cheer team got a pretty good laugh at the kid who drove his old sports car into their trashcan and made the engine die. I wasn't checking them out I swear! They'll never believe me.
- Andrew
81SC
Old 12-21-2010, 03:56 PM
Max Sluiter
Flieger's Avatar
I will have to remember that one when Spring Quarter starts. Although, I will have to add a flourish with a handbrake turn in my best TopGear tribute.
Old 12-21-2010, 09:05 PM
