mca mca is offline
mca's Avatar
Need to Resolve Paint Code Issue - Chiffon White
Trying to get my H4 trim rings painted. Can't seem to get a good paint code - even from the dealership using my VIN.
Can you guys please point me in the right direction?
Color is Chiffon White (L182) according to Dr. Colorchip's site: Select Paint Color - Dr. ColorChip: Automotive Paint Chip Repair Systems
I need to translate L182 into something that local shops can use to mix the paint.
VIN# is WP0AA0915CS121709
Thanks!
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-22-2010, 07:33 AM
RETIRED
Joe Bob's Avatar
You can order the paint from PaintScratch Touch Up Paint, Spray Cans, Paint Pen
2012 ML350 3.0 Turbo Diesel
Old 12-22-2010, 09:04 AM
mca mca is offline
mca's Avatar
I actually just got to the bottom of it.
Turns out that DuPont has "P2" in their database which is a match for Chiffon. The guys painting my trim rings use a different supplier - and that supplier could not make sense of the codes I provided.
So if anyone else has a similar issue, search for a local DuPont paint supplier.
Old 12-22-2010, 09:06 AM
