Lifting a 3.2 off the stand
Is it safe to lift a 3.2 off the stand by putting a strap around the intake manifold or should I take it off the stand using the lifting hook and then install the manifold. I am just worried that something will break and the engine will end up on the ground.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 09-19-2019, 12:03 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Tom - check out the link below to an earlier thread with some suggestions. Hope this helps you out a bit!
getting engine off the stand
Old 09-19-2019, 12:23 PM
Chain fence eating turbo
No! Do not lift the engine by the intake manifold. It is 2 piece with a rubber coupler along with being thin-wall cast aluminum. Even if 1 piece, I doubt the intake could take the load and would break in pieces.
There's lift tabs to use.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-19-2019, 12:49 PM
So none of these ideas work for me but it made me think that I should use my two post lift to pick it up from the bottom with some 2x4's.
Thanks Dmitry!
Tom Feeney
1970 911 T
1973 911 T
Old 09-19-2019, 12:53 PM
I couldn't get it on the stand with the lifting hook because it was too steep of an angle (hook is in the back of the engine). I thought I would have the same issue getting it off the stand.
Tom Feeney
1970 911 T
1973 911 T
Old 09-19-2019, 01:14 PM
911T70's Avatar
Here's how I do it with my 2.2 engine:
https://www.youtube.com/watch?v=eAZm6SyTS1U
Michel
1970 911T
Old 09-19-2019, 01:35 PM
There's always the Kubota method:
Bob D.
'84 Carrera - MAF, Wong chip, RSR flywheel, ER bushings and other bits, CTR fiberglass F/R bumpers, 7/9 Fuchs, 21/27 TB, 22/21 SB, bunch of other little stuff
'74 Fiat X1/9
2021 X5
Old 09-19-2019, 06:37 PM
i just bring a pallet up from underneath with my forklift.
not as cool as using a tractor to be sure...
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 09-19-2019, 08:38 PM
Hi
Targa Me's Avatar
I used a chain hoist to lift my engine and place on an engine stand.
There is an eye lope at the rear of the engine (clutch side) and I used the mounting cross bar to hook up the front.
If you look at the front of the engine you will see two small C-clamps. I placed those there so the chain link would not slide from side to side while I was lifting the engine.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 09-20-2019, 12:03 PM
911T '72
DeRRis's Avatar
That's magic
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 09-20-2019, 12:40 PM
