no engine seriel number?
Hi All
My first Porsche is a '78 SC Targa that I've had for more 12 great years of very happy and spirited motoring.
The other day I noticed that the engine seriel number that would/should be on the vertical support casting of the fan housing has been removed somehow - its not there.
Now, being that the car has had a couple of previoius owners, while it looks to be a proper 3.0 SC motor, I always figured this isn't the original engine ... but why would a previous owner remove that? What would that indicate?
Kerry
'78 911sc Targa
'81 928
'02 Boxster
'89 944 Turbo
Old 12-23-2010, 07:09 PM
Danny_Ocean's Avatar
Manufacturer replacement?
Old 12-23-2010, 07:22 PM
techweenie's Avatar
Best scenario: never-stamped replacement case.
Worst scenario: serial number ground off.
It's easy to tell. Look for the "type" stamp to the right and below the serial number surface.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 12-23-2010, 07:28 PM
hmmm...there is no type stamp either.
Kerry
'78 911sc Targa
'81 928
'02 Boxster
'89 944 Turbo
Old 12-24-2010, 01:00 PM
As both above said, the Porsche Factory replacement motors do not have serial numbers.
techweenie's Avatar
No type stamp means it's a replacement case. That's a good thing.
1969 coupe hot rod
Old 12-24-2010, 01:11 PM
thanks all!
Kerry
'78 911sc Targa
'81 928
'02 Boxster
'89 944 Turbo
Old 12-24-2010, 01:14 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
This is a christmas present to ME. I bought a 964 engine 6-8 years ago and noticed after I received it that it had no S/N. The story was that it was purchased from Porsche, new, to go in a different car. Their story was that the replacement engines do not have s/n. This is the first time I've seen confirmation. Thanks, Merry Christmas
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 12-24-2010, 02:38 PM
ASE Master Tech - 35 yrs
larrym's Avatar
my 7R replacement case has no numbers -
(so you can make it anything you want it to be if you can find a "star" stamp to surround the numbers)
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 12-26-2010, 12:38 AM
larrym's Avatar
Unhappy
but I should also say that I once bought a 75 targa and later discovered no LEGIBLE numbers on the obviously 76 model engine and suspiciously 76-like body
P.O.'s explanation was that it was a 1-made-of-2 salvage car from a employee at a noted porsche wrecking yard, which yard then professed no knowledge of the car or the guy who supposedly built it in their shops
Old 12-26-2010, 12:48 AM
