-   -   bent front t-bar adjusting bolt, no front sway bar (http://forums.pelicanparts.com/porsche-911-technical-forum/582509-bent-front-t-bar-adjusting-bolt-no-front-sway-bar.html)
deeking55 12-28-2010 07:04 PM
I am not completely new to the forum as I have been reading for months but I have not posted much due to my lack of knowledge. For reference sake, my beautiful wife gave me an 83 SC for Father's day last year. It has been lowered and converted to carbs although I am still trying to figure out what suspension mods have been done. It does not have a front sway bar - would there be a good reason for this at all? The rear has new Weltmeister bushings and measures to 21mm so I believe it has been upgraded. In addition, my front drivers t-bar adjusting bolt is bent, I would like to pull the t-bars to see if they have been upgraded but I don't know how to remove a crooked bolt - any thoughts and ideas are appreciated.
many thanks-http://forums.pelicanparts.com/uploa...1293591854.jpg
Flieger 12-28-2010 08:22 PM
Cut the bolt with a Dremel tool. Carbide cutting wheel.
5String43 12-28-2010 10:16 PM
That bolt doesn't look like it's bent all that badly. I think I'd just try to back the thing on out. I'd be really surprised if you ran into too much trouble at all in doing that. One of the bolts on my '69 was bent worse than that and it worked just fine. But who knows what gremlins lurk? Your results may vary.
bkreigsr 12-29-2010 05:46 AM
looks like it will back out straight, only the head is messed up.
running with a rear 21mm and no front is asking for trouble. Bill K
ossiblue 12-29-2010 08:55 AM
Agree with the first sentence, and strongly agree with the second.
deeking55 12-29-2010 10:36 AM
Is there a reason one would have taken off the front swaybar? Secondly, is there a way to tell if the t-bars have been upgraded without removing them?
bkreigsr 12-29-2010 11:08 AM
first - accident? - could account for the bent adjuster?
second - not really. when the end adjuster is removed, you can see the t bar, but since they are all the same dimensions at the splines, you won't be able to determine the actual bar diameter by looking at the end. if you get lucky, you might see a hollow bar and know for sure its been swapped, but again the hole gives no clue to bar diameter. Bill K
