Thermostat (early) : absolutely won't come out
Is there any cool jig for this? Even with levers under the lips, I could not budge
the thermostat on my '70 engine. While the engine is out, I was going to test it and put in a new o-ring. It's probably not bad, but if it ever goes bad I have no way to remove it. Thanks
Mark S. '70 914-6 |
someone may have used a lot of sealant, which is not needed. use a couple of crowfoot tools and some more effort.
Remove the two M6 studs and try to rotate the thermostat first.
Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
RETIRED
Double nut the studs, remove, throw some Kroil or PB Blaster on it, wait an hour or more......twist....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Good ideas, will remove the studs. Also I have a bigger pry bar I can probably
grind thin to fit.
Mark S. '70 914-6 |
Okay, got it out making a very strong pry bar out of an old gear puller piece.
It fought all the way to the end. It was not possible to remove the studs since they didn't protrude enough to get 2 nuts on anyway.
Mark S. '70 914-6 |
Lube and wait...krol.. twisting usually works...torque!
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
