French Import
zippy_gg's Avatar
Engine Oil Cooler Seen on eBay
Is this worth looking into? Anyone using this?
Fits PORSCHE 911 1973-1989 and 930 Turbo 1976-1989. Over 500 square inches of surface area (internal and external) this is a precision made compact oil cooler. 100% aluminum for the most efficient heat transfer. Mounts without modification, no holes to drill & no oil lines to run. Takes the place of the "S" shaped hose that runs from the oil tank to the engine oil cooler. Can be installed simply during your next oil change. All hardware and clamps included.
See a 10 Degree drop in engine oil temperature.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-31-2010, 07:56 PM
LakeCleElum's Avatar
No experience myself, but other have posted on here:
DON'T WASTE YOUR MONEY
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 12-31-2010, 08:27 PM
walt's Avatar
Looks like insufficient area and air flow to dissipate much heat. Have you considered a cool collar .[img]
Walt
82SC 3.0
81SC 3.6
Old 01-01-2011, 05:26 AM
craigturbo02's Avatar
Don't waste your money plenty of manufacturers out there producing higher quality goods at simular price.
Old 01-01-2011, 05:40 AM
Are you having an oil over temp. issue?
Please give details, many here can help.
If not, do nothing re. this and concentrate on other projects.
Old 01-01-2011, 07:08 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Looks like a Cool-Collar wrapped around a 1" pipe...
Gary R.
Old 01-01-2011, 07:10 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Reminds me of a piece of heating element for hot water heaters in a house.
Basically they are a tube with fins on the outside....designed to give off heat.
Maybe you could find an old piece of that (junkyard...for free) and use that....LOL
Sorry 'bout the joke
Bob
Bob Hutson
Old 01-01-2011, 12:35 PM
Taking it apart is easy
Jerome74911S's Avatar
I asked a question about the same product some time ago, and here is one answer I got:
"There are SOOO many things wrong with those things I don't know where to begin.
Coolers should never be installed on the suction side of an oil pump, they belong on the pressure side, only.
Those brass fittings as pictured are VERY restrictive; something you really don't want on the suction side or anywhere else in the system.
Oil coolers are heat exchangers and that requires cool airflow to do a credible job of removing heat from the oil. There is insufficient airflow (cool or otherwise) in that location to make an effective "exchange" to shed heat.
JMHO, but if a person needs a reduction in oil temperature to extend engine longevity and maintain power, there are FAR FAR better solutions.
Steve Weiner
Rennsport Systems"
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 01-01-2011, 02:30 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Steve Weiner
Rennsport Systems"
Absolutely!
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 01-01-2011, 03:09 PM
Hi,
I'm going to be the odd duck out on this one! I had been having some heat issues with my 77S and after looking at all my options, (car has no plumbing for external cooling!) I decided that besides this, my next price point was approx. 2 to 3 grand!
I bought and installed one of these, but I also put in new plugs, wires, cap, MSD and coil, and adjusted my valves. So I can't give you anything near a scientific test on whether or not it solved my problem. I do know that during my summer trip from MN to CA my temps stayed slightly over 200 and would max at 250 driving up mountain passes. I was happy with these temps because in the past I had seen closer to 300(ouch!)
The cooler appears well made and is easy to install and hangs in airflow, so I have to think it does some good, but I wasn't going to change oil twice to get an actual "scientific" test!
-Rutager
Rutager West
Old 01-01-2011, 03:43 PM
I ran one of these for a couple of years, as I was getting high oil temps and needed something temporary. I finally got a real oil cooler in the front fender. The only thing this finned oil line did for me was added 2 more places where it could leak oil. I wouldn't recommend this to anyone. However, it may help reduce the really high oil temps on hot days. But it isn't a substitute for a real oil cooler. If you're having too high of oil temps, I'd keep my eye out for a used front fender oil cooler. They come up fairly often from folks parting out cars.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 01-01-2011, 03:53 PM
80-911SC's Avatar
sounds like the COOL COLLAR is the better option , installs easy, looks great and can be thrown away with the filter in the next oil change ....
Old 01-01-2011, 04:33 PM
French Import
zippy_gg's Avatar
Thanks for all the feedback and opinions. I do not have a hot temp issue and my 86 does have the front cooler, I was just investigating a product that claimed to drop the oil temp by 10 degrees.
Gilles & Kathy
Old 01-01-2011, 07:02 PM
IMO, save your money and look at ElephantRacing.com for real, reliable oil coolers and plumbing. I believe our host sells their products also..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 01-01-2011, 08:08 PM
RETIRED
Joe Bob's Avatar
Coolers don't drop "normal" operating temps, thermostats do. Bigger coolers keep the oil at operating temps longer when driving hard.
If your normal day to day temp is over 200F, then look at replacing your thermostat.
2012 ML350 3.0 Turbo Diesel
Old 01-01-2011, 08:56 PM
