twin plugged targa's Avatar
removing centre horn assembly on '70 911T?
My horn is upside down!
(Porsche emblem upside down on horn/steering wheel)
Is it a major ordeal to remove and turn 180?
This is on the 911T (1970)
Many thanks
Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 12-30-2010, 07:55 AM
Friend of Warren
A picture of the wheel would be helpful.
Kurt V
Old 12-30-2010, 08:07 AM
If you have a stock wheel, the horn pad with the emblem should easily be removed by pushing in with your hands and turning counter-clockwise (caution, remove the horn relay first!) about 1/8th turn to release it. You should be able to reinstall the pad correctly after that, but if not, you may need to remove the wheel and reposition it 180 degrees.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-30-2010, 08:28 AM
stock wheel
thanks
Old 12-30-2010, 08:33 AM
Thanks LJ will try the twist
rgds Ben
Old 12-30-2010, 08:57 AM
Actually looking at your photo, the wheel looks to be mounted upside down. I have the exact same wheel on my 73 and the seam on the cover is at the bottom whereas yours is at the top. I don't know if the pad is reversible 180 degrees but the wheel definitely is.
L.J.
Old 12-30-2010, 09:15 AM
