-   -   Adding lightness (http://forums.pelicanparts.com/porsche-911-technical-forum/582790-adding-lightness.html)
dede911 12-30-2010 12:18 PM
Adding lightness
Hi,
I'm looking for possibilities to save weight but want to keep the stock look.
The lightweight battery is already installed at the front.
Next idea is the remove the sound insulation under the rear deck and replace this insulation with dynamat. And then replace the original upholstery and seats.
Is this possible? How much weight can I loose?
Thanks,
Andre
drl911 12-30-2010 12:23 PM
Remove the windshield washer tank/pump/hoses.... water is heavy!
Wil Ferch 12-30-2010 12:45 PM
Lotsa posts on this topic....here's one with a weight chart---->
http://forums.pelicanparts.com/porsche-911-technical-forum/423361-438-lbs-gone-5-days-my-build-story.html
tcar 12-30-2010 02:12 PM
Pretty funny... just get rid of the water.
The whole thing only weighs about a pound, empty.
Plus, it's in the front... you want to get rid of rear weight first.
Green 912 12-30-2010 04:08 PM
% of weight lose won't change much of anything unless you go after many aspects that reduce street drivability. Stock Look or stock comfort. Stock look could include FG body and bumpers, and no AC.
