Suspension Advice needed
Hi
I have an 83 SC, about 95 k on it with mostly the original suspension (bilstein struts/shocks). I'm replacing the a arm bushings (elephant racing rubber) installing turbo tie rods, strut mounts, etc. The car is only street driven, never any track use. Should I be installing Biltein HD or Sports on both the front and rear? I dont want anything too harsh for a ride. Also as far as torsion bar upgrade, any suggestions for sizes? thanks.
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
2 different questions. If you up the bars, you should do performance shocks. If you want a nice street ride (remember, a 911 is pretty damn good stock), don't over dampen the suspension. It will become a harsh ride. Koni adjustables make a nice addition to a basically stock set up.
I think I hit a sweet spot using the Konis. Old pic of a car long gone to Europe:
AutoBahned
Bilstein might just revalve the ones you have - call them with your info (one guy there & it's been posted before) after you decide what t-bars to use
Why do you want to replace the shocks or put stiffer springs on if it is street driven?
What do you consider harsh? The 86 911 had 25mm rear torsion bars and 22/21 sways which would be a small step up from your 24mm torsion bar and 21/18 sways. 22/28 torsion bars are a street-able and fun on the track set up. Usually this is where most go. |
Since you are asking about larger torsion bars, I assume you want to reduce body roll, squat and dive.
Ride quality is subjective, but - 21/27 is good balance for an SC and provides a nice street-oriented upgrade to control. When paired with bilstein HDs provides a ride that most enthusiasts would find very suitable on the street. 22/28 or 22/29 with sports is also a nice combo albeit noticably firmer - yet still streetable. Your wife might disagree. Stiffer than this and most will find it too much for the street except for occasional use, sporting purpose cars.
Chuck Moreland - elephantracing.com - vonnen.com |
It's perfect for my heavy ride. Great control and confidence in any crap interstates can throw at you at speed. It's never sloppy nor irriating hard to spend all day on. Add good bushings & summer only tires and the car becomes a go-cart.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Less brakes, more gas!
You may consider keeping it all stock. You are replacing the 30 year old crap that makes the current susp. just not work right. After you replace all the crapyou will return the car back to almost new performance and that may be enough for you. Lower to euro height or a little lower and see how you like it.
However, if your car is like mine, I found that the front t-bars were so rusted that they were not to be used again. I was replacing them anyway, but in your case you may not be and run into the need. Used SC/Carrera t-bars in good to mint condition can be had for very little $$ in the Classifieds here. I have a set of rears in mint cond. FS now. <-- shameless sales plug ![]() For your street car I would suggest to following list of replacements: Front: A-Arm bushings Turbo tie rods Rear: Spring plate bushings Note, I would not recommend going to monoball strut tops or rear trailing arm mounts. If you want to do the Low Friction mount kit on the front A-Arm you can, but IMHO not needed for a street car. I have it on my track rat though. I just pressed out the stock top shock bushings on my car and they were in great shape so I would assume yours are as well. Now... if you want to move toward a sports purpose car... that's a slightly different thing, but you are doing the hard part now. With an all new bushing setup moving in that direction will be a LOT easier in the future if you choose to do so. Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS Last edited by euro911sc; 12-07-2010 at 07:11 AM.. |
Thanks everyone for the replies. I'm mainly looking to make the car drive better. The car handles poorly in its current state. I have a 91 GTI with bilstein sports and sport springs and it will drive circles around the 911 in any situation. I'll start by taking it apart and see what is worn out, it may end up going into new torsion bars, struts, etc. I don't mind a firm ride, but not something that kills your kidneys over our great roads.
I'll keep updates as I go forward with this!
Update so far...
Got the front end apart...Hmmm The front T bars are rusted and have a groove worn in them from rubbing.. Control arm bushings are worn off center on the rear bushing, and there is slight play in the strut between the insert and the housing.(very slight but noticeable). As mentioned above, maybe 21/27 T bars, new ER rubber bushings in the front end, (rear were done last year), turbo tie rod kit, and it looks like Bilstein HD on all 4 corners. I just hope that this will make a nice streetable car that won't be too harsh!
The 21/27 HD combo will provide a nice street car that corners flatter and feels much more controlled than stock.
[QUOTE=gtihop;5712698] The car is only street driven, never any track use. Should I be installing Biltein HD or Sports on both the front and rear? I dont want anything too harsh for a ride. QUOTE]
Then I would leave it alone. It's not that easy to improve the way they came from the factory and much easier to screw them up. When was the last time it was aligned? |
[/QUOTE]Then I would leave it alone. It's not that easy to improve the way they came from the factory and much easier to screw them up.
When was the last time it was aligned?[/QUOTE] It was aligned last summer..I agree it's easy to screw up, that's why we ask questions from the experts that deal with this everyday so we can get the results that we're looking for.
After a PM pointing out my "attitude" I should clarify a bit it seems. I have 0 respect for driving at speed on the public road, and I believe that may have come through in my comments. I have become a PCA National Instructor over the last couple years and I see the look of astonishment on student's faces that 1st day on the track, astonished at what they think they knew was right and isn't. GTIhop wasn't talking about street racing so to him I apologize. That said, I advise any and all that have not been to the track and that want to learn to drive their car well to do so. Even 1 weekend invested will wake you up to the real beauty of these cars.
Gary R. Last edited by GaryR; 01-02-2011 at 09:46 AM.. |
[/QUOTE]Just remember, the true experts that deal with this everyday were at the factory. |
French Import
That will be the present to myself once I am done replacing the worn out suspensions and brakes. Nothing beats track time with a professional instructor.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
