-   -   O2 sensor rewire (http://forums.pelicanparts.com/porsche-911-technical-forum/583082-o2-sensor-rewire.html)
aston@ultrasw.c 01-01-2011 11:33 AM
O2 sensor rewire
I have a new O2 sensor 928-606-124-00-M14 with two connectors.
I actually need a one connector type 965-606-126-01-M14
Can I cut the connector off my old sensor and reterminate the wires onto the new (wrong) sensor?
If so, which wires go where?
TIA
tuned6 01-02-2011 12:08 AM
Either checker or Bap have a generic Bosch o2 sensor for $20. Bosch sensors with connectors are typically around $70. I wouldn't cut it and return it.
I've been using the twenty dollar ones and they are great.
Good luck
Chris
Louie85 01-02-2011 07:11 PM
the black wire is the sensor the two white wires are heater for the sensor.
Hope this helps.
Louie
aston@ultrasw.c 01-02-2011 08:25 PM
I have discovered that Bosch make universal sensors that can be spliced into existing wiring.
I think this is a good indication that splicing the old connector will be OK. Here's a link to the installation instructions.
http://www.clarks-garage.com/shop-manual/OxygenSensorInstall.pdf
