tomeric914's Avatar
Collapsible Oil Return Tube Installation - Should the snap ring be closer?
Putting everything back together on this "project" engine and notice that with the return tubes fully extended into the head and case, there is about a 1/4" gap between the snap ring and inner tube half. This seems to be ok because the snap ring is really only there to prevent the tube from collapsing too far and falling out.
I can push the tube together and it's still well in place. Any thoughts?
Old 01-01-2011, 07:07 PM
Senior Advisor
James Brown's Avatar
That's it, you got it.
08 Cayenne Turbo
Old 01-01-2011, 07:58 PM
Checked out
McLovin's Avatar
Originally Posted by tomeric914 View Post
Any thoughts?
Use the factory collapsable tubes and you don't have to worry about such weirdness.
The factory tubes don't cost very much. There's no reason to not use them.
Old 01-01-2011, 09:21 PM
Senior Advisor
and they do fit tight
08 Cayenne Turbo
Old 01-01-2011, 10:07 PM
Band.
Any thoughts?
Clean your engine case!!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-02-2011, 06:16 AM
tomeric914's Avatar
Thanks James.
The billet tubes came with the engine so I decided to try them out. I want to run the engine to see what I have, then go from there. I'll go back to the one piece design when I rebuild.
Old 01-02-2011, 07:00 AM
