CurtEgerer's Avatar
1974 Ignition Key
Can someone post a photo of an original ignition key for a '74 911? Thanks!
1983 AUDI Turbo Ur quattro
1987 PORSCHE 944 turbo
Old 01-03-2011, 03:36 PM
CurtEgerer's Avatar
Trying to figure out if the 74 uses the same style key as an early 911. Does the plastic part of the key look like this? Thanks.
Old 01-04-2011, 01:20 PM
RETIRED
Joe Bob's Avatar
Red is the Valet key. Will start the car, and do the doors but not the trunk and glove box. I see a friction shift lever there.....Campy?
2012 ML350 3.0 Turbo Diesel
Old 01-04-2011, 01:35 PM
CurtEgerer's Avatar
Campy? Good eye! I lightened it just a bit ....
I know the red is the valet but just need to know if the key style is the same. I don't think the key that came with my 74 is original.
Old 01-04-2011, 03:53 PM
RETIRED
Joe Bob's Avatar
The 914s came with those keys from 70-76. Dunno about the assdraggers of that time period.....
Old 01-04-2011, 03:55 PM
Curt,
Looks the same as my '74 Carrera,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-04-2011, 04:16 PM
74 & 77 keys
The key on the left is for the 74 911S Euro and the key on the right is for my 77 3.0 Carrera Euro. they both have lights The smaller black key with my 77 key is the valet.
hope this helps
Old 01-04-2011, 04:57 PM
CurtEgerer's Avatar
Thanks Steve, that's what I was thinking.
My key looks like 77 3.0 pictured. I suspect it is a replacement. Now I need to find some proper blanks.
Old 01-04-2011, 07:22 PM
Send a message via AIM to fintstone
The 74 key looks like the red one, only black The ones with the lights and crest can be cut to fit a '74, but they are not correct/original. They are for later models.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 01-04-2011, 07:38 PM
RETIRED
Joe Bob's Avatar
The lighted head and key blank is being sold for 60 bucks....head plus blank. The problem is finding the blank for the pre SC models. The blanks are 35 bucks alone.
928, 944. and 968 blanks using the same head are 9 bucks....go figure.
I cut down a black plastic headed key and modded the top with a Dremel. Got it to fit the lighted head.
Old 01-04-2011, 07:46 PM
your key is matching my 74 NOT the 77 3.0. the key for the 77 is larger than the 74 and the 74 key in the pic has the smaller key for the lug nut locks. sorry bout the confusion, I get my right and left backwards some times.
Old 01-04-2011, 08:37 PM
Send a message via AIM to topgub Send a message via Yahoo to topgub
flinstone is correct. The black key similar to the red one pictured is the 'master key'; it works every lock on the car. The red key pictured is a 'valet key'; it works only the ignition & the doors, not the glove box or the trunk on targas.
Mike
'74 Slantnose Targa/Cab project
'75 Carrera Targa
'82 SC parts cars (2)
Old 01-04-2011, 11:15 PM
My 74 original master looks like this one my origonal vallet looks like the red key above and I had a spare made that looks like the middle lighted key above.
Old 01-05-2011, 03:42 AM
Is it possible the key blanks used in Europe may be different from the spec US as far as being lit and the blanks used. Both of my keys are very old and are master keys having different groves than my red valet key. Oh by the way, the difference in the key blanks are the thicknesses allowing groves in the blanks for accessing all locks and compartments.
Old 01-05-2011, 07:50 AM
the key you have pictured looks like a valet key to me (even though it is black) not having the extra groves indicating a master key. At least this is how it was shown/explained to me from a master lock smith. I could be wrong.
Old 01-05-2011, 07:53 AM
There were only the two style keys for 74. The red and the black plain, unlighted ones. You can always go to the dealer and have a later lighted key with crest cut for your '74 as many have done...including myself, because it saves the original key and provides a light. The lighted, crested keys were unavailable in 74. Probably battery technology wasn't even there as even calculators were like bricks then.
Old 01-05-2011, 10:29 AM
RETIRED
Joe Bob's Avatar
Valet versus Master......umm, since NONE of us would likely trust a valet to park our rides, as long as the key works ALL the locks....who cares?
My valet key got the float test years ago....
Old 01-05-2011, 10:36 AM
mspirito's Avatar
I found a Key Blank on another site , was only 10 $ last year. Look around and you can find them fairly inexpensively. mine was identical to the original 74 carrera key that I had
Old 01-05-2011, 10:43 AM
Midwest R Gruppe
t6dpilot's Avatar
Curt, for further clarification, my 75 has identical key blanks as my 71. Therefore, the 74 should be like an early car, not what you have.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 01-05-2011, 12:02 PM
