New Project
Coffee Table
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
More photos
Coffee Table
Just what your wife would wish for. I have been working on this for over a year, off and on. I just completed the two end plates.. They started out as two 46 pound aluminum plates and after 35 hours of machine time less than 9 pounds each. The glass will sit on the carb stacks. It will have all parts except a shroud, even a aluminum fly wheel
French Import
Hmmm... Just wondering...! Are you going to install a Steve Wong chip?
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Very good.
I would add a few touches: Remove #2 & #3 cylinders and expose the pistons in operation. (Need crankshaft and connecting rods). Add clear valve covers and chain covers to expose the machinery. Has anyone done this with articulated (moving) pieces? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Table
Motor is hollow. I cut the end off a old crank shaft to mount the fly wheel. It's going in my den which is on the second floor. I was trying to keep the weight down. The idea of a cutaway is very interesting and I wanted the motor to be stock so I left the Steve Wong Chip off.
1984 Carrera Coupe 3.2
Hi Banker, Any idea on the weight of this beast? Pretty cool idea actually-seems like a good way to store parts in plain sight! Looking forward to the finished product...
Very nice work, it looks great.
One note - The 1-2-3 cylinder Zenith carb is backwards! ![]() One question - does it leak oil on the floor like the one in my car? If not, I'm not sure it is authentic!
Chet Dawes 1971 Porsche 911T Coupe 1974 Porsche 914 2.0L 2004 BMW 330i ZHP Sedan 2008 BMW X5 4.8i Sport |
French Import
Technical question: will the table be on carpet, hardwood, or tile?
This will dictate the type of pad under the "stands" or even if more pad width will be needed so you don't damage your florring. Do you have an idea of the total weight, including glass top?
French Import
