sudo apt-get purge 930
equality72521's Avatar
Fixed back seat question
How feasible is it to use the factory three point seat belts with a fixed back seat? Is it possible? Is it recommended? I don't really want a harness bar and harnesses for a car that is 99.9% street. However, I like the low weight and the looks of a fixed back. I currently have OEM sport seats that need work that will probably cost more to refurbish than a new set of seats. Thoughts???
--clutch-monkey
Old 07-29-2010, 07:27 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Not a seat safety guru but I can't see where there is risk to using them unless your new seat sits so low that the lap part of the belt rides on your belly rather than your pelvis. That could kill you dead.
You want to sell those sport seats?
Old 07-29-2010, 11:32 AM
I will if I buy new seats.
--clutch-monkey
Old 07-29-2010, 11:39 AM
Bandwidth AbUser
Jim Richards's Avatar
Recaro pole positions with factory 3-pt harnesses on the street (wife loosened her belt a bit - sorry Mr. Safety, where ever you are)
Jim R.
Old 07-29-2010, 11:51 AM
Bill Verburg's Avatar
factory 3 points work fine w/ fixed back seats, the only sort of tricky part is deciding where and how to mount the tunnel side receiver. On seats w/ high thigh bolsters the receiver will have to be mounted in the lap belt hole, w/ lower bolsters you can usually run it out side the bolster
high bolster w/ receiver through the lap hole
these are Pole Positions and just about the highest bolster that will allow out side receiver mounting
Bill Verburg
Old 07-29-2010, 12:00 PM
I don't want something too severe as I want comfort for daily driving. The two I'm looking at are the Sparco Speed 2: Sparco USA
And Sparco Chrono Sport: Sparco USA
--clutch-monkey
Old 07-29-2010, 12:09 PM
H-viken's Avatar
The Recaro Pole Positions are surprisingly comfortable and they make a version for the stock 3-point harness. I haven't had mine for that long, but made a weekendtrip and was very happy with them (4,5h to the track. Trackday the following day. Then 4,5h back home the next).
/Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 07-29-2010, 12:30 PM
Bandwidth AbUser
We drove about 6kmiles in 2 1/2 weeks with the Pole Positions. My wife thought they were more comfortable than any Porsche seats she's ever sat in.
Jim R.
Old 07-29-2010, 12:37 PM
Pole Positions are out of my price range.
--clutch-monkey
Old 07-29-2010, 12:51 PM
Mark Mcgarry's Avatar
I have the same question and was looking at these.
Cobra Classic RS Fixed Black Sport Seat
81 930 euro sunroof delete
Garrett custom turbo, Tec 3 EFI, 964cams, GT3 oil pump
Andial intercooler, Tial wastegate
RarlyL8 headers and muffler
Lindseys 9s 11s
Old 07-29-2010, 01:04 PM
I know which seats I want, I just need to know if a three point system is feasible and safe to use with them. I can't spend $1500+ on seats, too much else to buy for the car.
--clutch-monkey
Old 07-29-2010, 03:34 PM
So what do you guys think of the Chrono Sports? Will I have a problem?
--clutch-monkey
Old 07-29-2010, 08:27 PM
First of all .... using a fixed-back bucket seat is no problem....look at how many RUF's and high-end sports Porsches are delivered that way in Europe. You most likely will need a lap hole and the versions you are showing don't have this. The first model you show is a tubular steel frame model and I have not found those comfortable. Look also at Cobra and Sparco Evo/Evo 2.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-02-2010, 10:27 AM
"First of all .... using a fixed-back bucket seat is no problem"
It may be a real problem, it all depends on your body build. Being tall, I need a recline just to fit. It's too bad that you can't try new seats on an extended drive before purchasing. Rob
Old 08-03-2010, 07:27 AM
Exactly! It sucks trying to decide on a seat without being able to test fit.
--clutch-monkey
Old 08-03-2010, 07:32 AM
gtc gtc is offline
abides.
gtc's Avatar
I would strongly caution anyone against buying a seat without sitting in it. I always thought I wanted Pole Positions, but when I finally tried them out I discovered that my torso is a little too tall for the shoulder slots.
I thought that the line of Sparco Evos are nice, fit well, and are fairly comfortable. The Evo 2+ was tall enough for me.
I was not impressed by the quality of the lower end Sparcos, and their styling was not a match for my car.
Just my two cents.... YMMV.... caveat emptor... etc etc blah blah blah...
Graham
1984 Carrera Targa
Old 08-03-2010, 09:25 AM
I would agree. I wanted SPGs originally, but where the shoulder wings sit was a bit too high for me and the bottom of them was in an irritating spot, so I ended up with Pole Positions.
You really wouldn't want something where the shoulder slots were placed badly, that would just be all kinds of annoying.
Also, on my Pole Positions, I never felt that the 3 points were all that well situated, they came through the shoulder slot a little funny and weren't tight enough near the lap belt slot, so I eventually just got the harnesses for it.
There really are quite a few nuances to making it work.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 08-03-2010, 10:32 AM
When I said there is no problem with fixed back buckets....I was answering the concern expressed by how the original 3 point seat-belts are asked to work. My answer meant to address the point that it is "no problem"... as many RUF's are delivered excactly that way and the upper portion feeds thru one of the uper-seat holes as does at least one side ( buckle) of the lap position... it's been done.
No question.....a fixed back bucket is not for everyone yet that said, there are multiple height mounting points for the front and back of the lower bolster when using side-mounts...that can help with the amount of "recline".
Wil Ferch
Old 08-03-2010, 02:51 PM
Happiest when Tinkering
gsmith660's Avatar
Do you have to have a fixed back seat? I love the feel of my hunsacker seats plenty of support definately will work with factory 3 points and will fold so my daughter can get in the back seat which is also 3 point.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 08-03-2010, 03:18 PM
No, I don't have to. I just want the light weight. I have factory sport seats now but they need work. I figured I could buy new lighter seats for what it would cost to refurbish what I have.
--clutch-monkey
Old 08-03-2010, 03:33 PM
