Is my rear sway bar upside down?
Hi
I've had my 1987 911 G50 for 3 years and have heard some annoying knocking sounds at the back for the whole time i've owned it. Time to investigate! I've found that the rear sway bar is actually touching the tranny and if you heave it up and down it clunks on it. The question is, has it been fitted upside down at some point in its life? The "bend" which i assume is meant to help avoid contact with the tranny seems to be facing up but it seems to me it would be more sensible to have it facing down? I looked for pics of others but couldn't find any and the manual i have doesn't show the bend at all. See a pic of mine below. Appreciate any comments! Thanks
Pretty sure you've nailed it, but I'd have to take a look at mine to confirm.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
The angle of the pic makes it hard to tell which way it's oriented. I searched as well but didn't find any good pics of this year.
I think you have another problem if you can move it by hand, though. Check the mounts as they often crack.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
funny, mine is straight.
Rear sway bar.........
Texasscot, The rear sway bar was installed in the wrong orientation!!!!!! The fact that you could wiggle the sway bar is a sure sign of worn rubber bushings or loose mountings. Remove the sway bar and install it the other way. Driver side (now) goes to the passenger side to change the current orientation. You probably need a set of rubber bushings too. HTH. Tony |
Thanks guys, at least it didn't seem totally ridiculous!
here's a closeup that shows the "space" between the sway bar and the tranny, i think i could get a sheet of paper in there. i also think the slight movement is in the old rubber bushings (i hope!). An indication of the size of the gap between the sway bar and tranny on another car would be welcome before i pull it apart. Thanks for your help
Throw it on the ground!
Looks to be mounted upside down based on this pic from a 1987 G50 car. The bar clearly angles down.
![]() Also, have you checked your mounts for cracks? Very common failure item.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Many thanks to all. Problem confirmed.
Just removed sway bar. it definitely was upside down, it actually has a wear mark from the tranny. It was probably put in wrong when a previous owner welded one of the mounts (i just saw the repair). I think they are good as they sound ok when i hit them with a hammer ...Ordering new bushes now. I really appreciate the trouble everyone took to help, thanks again. btw shahram, the bend was put in when the G50 was introduced (i found that on other posts) Graham |
Mike Holbrook
While you are under there and in the vicinity, how are your tranny and motor mounts? I recommend the Sport Mounts from our sponsor if this is a street car primarily. You might also look at the front bushings as well. It is pretty amazing how 4 new mounts and new sway bar bushings front and rear will make a serious difference in ride, shifting, etc.
Mike Holbrook Meridian, ID 1979 911SC Targa |
Excellent! Glad we could help out.
Easily Confused
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
